leak down test results.
In the world of aircraft engines, 80 psi input, with 75% loss max = 80 over 60 on the gauges.
Is this a home made tester or an aircraft leak down tester.
I did a leak down check on my 4.9, it was hard to find TDC as there are no marks for 120 deg and 240 deg on the fly wheel.
Jim, the aircraft mech
remove all the spark plugs, squirt about 5 oz into each CYL. rotate the crank by hand, let sit for about 5 min and rotate again, keep rotating the crank every few min for about 1 to 2 hrs, then get a old blanket and cover the top of the eng and heads, crank the starter for about 10 seconds to blow out the ATF water Mix, do a comp. check, if good, replace the spark plugs and start the eng, it will smoke like hell for a few mins, untill the atf burns out, add 1 quart of ATF to your eng oil, drain the eng oil after 500 miles, the aft is high detergent and will clean the inside of your engine. Water softens the carbon and the AFT cleans and lubs the rings, I have used this to unstick rings for over 35 years, it works great, if the problem is only the rings that are stuck/frozen with carbon. hope that helps, Chellie
the holley 4bl threw me off
WikiAnswers - How would you know if its piston slap
here is some info i found on the web to Diag the knock,
PKRWUD
Senior Member Join Date: Sep 1999
Vehicle: 1995 Ford F150
A little info on bottom end engine noises:
Main Bearing Knock:
Main bearing knock is usually apparent when the engine is pulling hard, when an engine is started, during acceleration, or at speeds above 35 mph.
Loose Flywheel or Broken Flexplate:
A loose flywheel or broken flexplate can usually be detected by this procedure:
1) Advance engine idle to 2000 rpm.
2) Turn off the ignition switch.
3) When the engine has almost stopped, turn the switch on again.
4) Repeat this procedure several times.
5) If the flywheel is loose or the flexplate is broken, a distinct knock will be heard every time the ignition switch is turned back on.
Harmonic Balancer:
A separated harmonic balancer will generally produce a heavy rattling noise that can be heard at low speed.
Rod Knock:
Excessive connecting rod bearing clearance noises are usually a light rap or clatter much less in intensity than main bearing knocks and the loudest when the engine is "floating" or running with a light load at from 25 to 35 mph. The noise will become louder as engine speed is increased. By grounding out each of the spark plugs, one at a time, you can determine from which cylinder the noise is coming. The noise may not be eliminated entirely by grounding, but it will be reduced considerably in intensity. The easiest way to ground out the cylinders is by inserting a 1.5" piece of 5/32" vacuum hose on each terminal on the distributor cap, and then placing the spark plug wires over the vacuum hose. With the alligator clip end of a non-powered 12 volt test lamp attached to ground, touch the test light tip to the vacuum hose to ground out that cylinder.
Piston Slap:
Piston slap is loudest when the engine is cold, and lessens or disappears after the engine is warm. When driving the vehicle (at from 25 to 30 mph) the noise will increase in intensity as the throttle is opened and additional load is applied. To detect piston slap, try the following procedure:
1) Pour several ounces of 40 weight engine oil into the suspected cylinder(s).
2) Crank the engine for several revolutions with the ignition turned off. This will allow for the oil to work itself down past the rings and act as a cushion.
3) Install the spark plug(s).
4) Start the engine.
5) If the noise is eliminated, the engine has a piston slap condition.
Piston Pin Noises:
Piston pin noise is usually the result of excessive piston pin clearance. This will cause a sharp, metallic, double-knock sound most noticable when the engine is idling. Sometimes the noise is more audible at car speeds of from 25 to 35 mph. To test for excessive piston pin clearance noise, use this procedure:
1) Run the engine at idle speed.
2) Retard the spark to reduce the intensity of the knock.
3) Return the spark timing to the normal setting.
4) Short out each spark plug, one at a time. The double-knock sound will become more audible at the cylinder with the loose pin.
If you have high mileage, and i think you do, use Valvoline 20w60 raceing motor oil, it will help to cushion piston slap if thats what you have, i would use it any way, since your using a 4 bl carb, looks like you want to do some raceing
Valvoline XLD HI-VIS
Valvoline XLD Hi Vis is a 20w/60 high viscosity enhanced mineral oil . It is a shear stable lubricant designed for engines requiring a viscous lubricant . XLD Hi Vis is especially suited where oil consumption may be an issue .
XLD Hi Vis reduces oil consumption & maintains oil pressure in high mileage engines .
<TABLE cellSpacing=0 cellPadding=0 width=330 height=36><!-- MSTableType="layout" --><TBODY><TR><TD vAlign=top width=122>
you have lots of bearing clearance if 20w50 did not help to bring up the oil press up. Take care, Chellie
