Before I take my Excursion in for service, I'm wondering if anyone has had a similar situation. When I turn on the air conditioning, it blows warm for at least 5-10 minutes, then slowly gets somewhat cold after 15-20 minutes. It never really gets as cold as my other vehicles, though. Would a refrigerant charge take care of it?
I live in South Florida and mine takes about a minute to start getting really cold. I run the rear AC too just to cool the truck down. 15 minutes is way to long.
Mine blows warm air and never gets cold. I put a can of freon in it but there was no change. There is a clicking noise every 2 seconds that comes from the passsenger side near the firewall and I'm pretty sure the pump is cycling on and off because it drops a couple rpm's every time it clicks. I checked the vents and also there is no leaks.
Don't just start dumping R134a in. You need to test the pressure first. Too much is far worse for the system than too little.
1) Test the current charge. There are cheapo gauges at the auto parts stores that will read roughly the charge. Note that you need to compensate for the outside air temperature.
2) Clean your condensor coils.
3) Check that your cooling fan is moving air.
At idle the system design appears to be weak for very hot temperatures. So if you are spending a lot of time sitting such as in stop and go traffic it appears to be normal for the diesels not to produce strong A/C. My hypothesis is that the idle speed is too low to cool the large volume of air in these trucks as increasing the idle speed results in noticeably more cooling in a properly charged vehicle.
clicking sound is the tell tale sign of compressor issues. It could be a relay, clutch or the actual compressor unit.
or not enough freon in the system.That's my bet. Once the compressor stays on the clicking will go away. i believe your electric clutch is kicking on and off when the pressure drops. Might try another can but gages are your best bet.
I doubt it that is it because after I added the can it made zero difference and the clicking noise wasn't there before.
So the fan is blowing the air out the vents but the compressor isn't pumping the freon?
the blower fan can blow all it wants, if the compressor/evaporator/etc isnt cooling the air, it will just push out hot air.
Grab the lines by the drier. They should be cold enough for you not to be able to hold them for too long. If they arent, you either have a leak (low freon) or the expansion valve may be stuck closed.
That clicking sound under the dash will probably turn out to be the Blend Door Actuator. It's not allowing the blend door to close off airflow to the heater core completely.
You will also need very likely need to have the refrigerant recovered and the system recharged to get rid of the overcharged condition that can damage your AC compressor.
Adding refrigerant is NEVER the first step in AC system diagnosis.
