brake Portioning valve
Old Jul 17, 2010 | 10:43 PM
1969furd's Avatar
1969furd
smalll update, i got the old valave off, all the brakes replaced but in the process i fed up drivers front brake line, and the porpotioing valave that i got from bronco graveyard soent fir, the line going to the reaer from the master cycinder is too small for the hole in the new valve, so what do i do now???
Old Jul 17, 2010 | 11:28 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Find a local fastener or pipe & fittings place and see if they have an adapter. They should have just about anything.
Old Jul 17, 2010 | 11:31 PM
1969furd's Avatar
1969furd
i will check on monday
Old Jul 18, 2010 | 01:05 AM
TruckGirl74's Avatar
TruckGirl74
this was the first problem I had with my truck that lead me to this site...bought the same one you did, funny thing is we still have not installed it. We ran into all the same problems you did with Napa, Riebes, Kragens etc. and all the junkyard ones had the same problems as the one on my truck.
The only thing was there is only one lead going into the new one but two leads on the truck, was told that both can be attacked to the one but that sounds hinky to me. Let me know if you run into any problems and I will do the same because we are suppose to install it this week
Old Jul 18, 2010 | 07:49 PM
NBC-Steve's Avatar
NBC-Steve
I just replaced my proportioning valve and I had the same issue. The fix was an adapter I found at our local Kragen store. I took the valve with me and they let me go behind the counter to try the different sizes.
Then I had to modify the warning light switch by identifying the positive lead and connecting that to the switch. The negative lead was grounded to the chassis.
Good Luck!
Craig46
1947 and Older Ford Trucks
35
Dec 19, 2015 02:16 PM
bstidham
Oct 4, 2015 03:20 AM
Grinder Man
Oct 10, 2014 09:35 AM
PA F250
17
Aug 28, 2013 06:35 AM
