fuel tank drain plug.
Old Jul 8, 2010 | 02:35 PM
04markIII's Avatar
04markIII
don't laugh! being that our tanks are plastic, is it possible to make a drain plug setup? reason i ask is that my fuel gauge is way off, and i'm sure it has to do with the sender placement. tank was dropped a few months back to replace what was thought a faulty fuel pump. now the tank will be empty, but the gauge will say a little less than 1/4 tank. i keep track of the mileage, but that's a pita! didn't know if the fuel was drained, then the mechanic could see where the sender is in relation to the bottom of the tank and make the proper correction, as opposed to dropping the tank over and over and over again. just some stupid rambling!
Old Jul 8, 2010 | 03:48 PM
alloro's Avatar
alloro
Yes, but I believe the real reason fuel tanks don't have drain plugs is because of the potential for them to leak. It was always rumored that the reason was because it would make it easy to steal someones gas. But that's just baloney because those people usually just puncture the tank or stick a hose down the filler neck.
Old Jul 9, 2010 | 12:09 AM
etewald's Avatar
etewald
or just keep the tank over 1/4 full.
Old Jul 9, 2010 | 08:24 AM
04markIII's Avatar
04markIII
i watch the gauge, and i know roughly when to add more fuel, but i would prefer it to work as intended.
Old Jul 9, 2010 | 11:02 AM
alloro's Avatar
alloro
Then you're stuck dropping the tank and bending the float arm.
Old Jul 9, 2010 | 11:08 AM
04markIII's Avatar
04markIII
Old Jul 9, 2010 | 11:39 AM
Moto Mel's Avatar
Moto Mel
Get 5 gallons of gas in a jerry can and drive it out of fuel. Note where the gage is pointing and adjust your self to it if you don't want to R & R the tank and adjust the float.
Old Aug 19, 2010 | 01:32 AM
wardwoodworks's Avatar
wardwoodworks
plastic fuel tanks install drain plugs
attwood rubber drain plugs
has friction fit drain plugs check it out
other place for rubber drain plugs for plastic tanks in your local bobcat dealer. on the fuel tanks and chain case they use a rubber plug with a metal insert. mine was off a 2000 873G
Old Aug 19, 2010 | 04:21 PM
hodges710's Avatar
hodges710
Hello Alloro, I am not sure on all ford models but I have seen some that had like little security type screening or whatever the material could of been in the filler neck/tube. I had a 93 F 150 dual tank setup and both had it and my 98 expedition cant be done either. On my expy, I found out when I myself tried to get some gas out of it when I had it parked last winter for about a month.
HoustonDave
Oct 18, 2016 10:08 AM
waituntilthebeep
Mar 13, 2016 08:35 AM
AtlM5
Dec 13, 2015 07:46 PM
utclark
6.7L Power Stroke Diesel
Sep 9, 2015 08:11 AM
HD Rider
Apr 9, 2010 06:53 AM
