Sponsored by: Real Truck
np273f
Old Jul 8, 2010 | 09:49 AM
429poweredf350's Avatar
429poweredf350
np273f
I have an 06 F350 crew DRW. Truck has 46K miles on it. At certain speeds, the transfer case groans. Some have suggested the transfer case shift encoder motor. What are the symptoms when this unit goes bad and is there a way to check it before replacement?
Thanks
Old Jul 9, 2010 | 12:34 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
How do you know it's the transfer case?
On that truck, you have a hanger bearing for the driveshaft - that's the more likely problem.
Old Jul 9, 2010 | 03:27 PM
429poweredf350
Carrier bearing is new. crawled under it on jackstands.......deffinitely the case
Old Jul 9, 2010 | 04:33 PM
krewat's Avatar
krewat
I doubt the servo motor would do anything, sounds more like the bearings in the transfer case. Did you check the fluid yet?
Jerry37323
Sep 14, 2015 10:51 AM
Truck Guy99
Feb 19, 2014 12:20 PM
EASTSIDEAUTO
Jan 13, 2012 05:19 AM
Michael Ides
Jun 12, 2010 07:39 AM
Katmandu
Nov 19, 2008 08:38 PM
