Sponsored by: Auxito
WILL-NOT-START
Old Jul 7, 2010 | 05:14 PM
adamax21's Avatar
adamax21
WILL-NOT-START
1997 f150 4x4 204K lariat 3dr. 5.4 auto. turns over great! refuses to crank. i sprayed a little starting fluid into the intake. it stuttered and crunk for a split second. i checked the fuses and found two bad, but i replaced them (i still need a fuse diagram). still wont crank. this trucks been stitting for 6+ mo. and everything LOOKS ok but im out of ideas. i did check the fuel pump reset and it was not triggered. if i slowly turn the key over, i never hear the fuel pump kick, but im not sure if im supposed, or even if i would be able to. no check engine light.PLEASE HELP!!
Old Jul 7, 2010 | 06:28 PM
Navyguns's Avatar
Navyguns
You should hear the fuel pump kick on when the is put to the run position.
Old Jul 7, 2010 | 08:58 PM
adamax21's Avatar
adamax21
thanks dude!! that solves about half the equation and give me a direction to go in! God bless!
Old Jul 7, 2010 | 09:52 PM
SYKOLINCOLN's Avatar
SYKOLINCOLN
hopefully your problem will be easier to fix then mine! good luck!
b4pjoe
1997 - 2003 F150
Sep 1, 2020 05:04 AM
ITSA'G'THING
Jun 2, 2011 10:06 PM
hammerin16ds
2004 - 2008 F150
Mar 13, 2011 04:50 PM
k_mowery
Jun 23, 2007 01:44 AM
Johnny one
20
Nov 20, 2005 02:42 AM
