What is 2nd best to Motorcraft parts?
Old 07-07-2010, 01:28 PM
erica's Avatar
erica
erica is offline
Question What is 2nd best to Motorcraft parts?
89 F250, 7.5L.......Having problems getting it started. Cranks like a champ but just won't turn over. My next step is replacing the distributor cap and rotor. This truck gets driven less than 500 miles during the year. Pretty much summer months only. Motorcraft parts seem so expensive compared to a few of the other brands. Is there a 2nd or 3rd best than I can use that would fit our driving habits for this truck? I thought I read somewhere that Autolite makes Motorcraft.
Old 07-07-2010, 01:44 PM
darthice's Avatar
darthice
darthice is offline
Autolite is a good brand I use alot of house brands like bwd and such from oriellys.
Old 07-07-2010, 02:01 PM
nstueve's Avatar
nstueve
nstueve is offline
I also go with Oriellys house brand quite a bit and have yet to be disappointed. Also it depends on what parts you are talking about... some brands are better than others depending on the part.
Old 07-07-2010, 02:07 PM
darthice's Avatar
darthice
darthice is offline
exactly and it also depends on the purpose if you are going for performance the house brands will not suffice but for most drivers the house brand will do fine.
Old 07-07-2010, 09:30 PM
fishforlife2007's Avatar
fishforlife2007
fishforlife2007 is offline
if you specify what exactly part wise you are comparing motocraft parts to, then we can better help you.
Old 07-08-2010, 01:13 AM
nighthawk285's Avatar
nighthawk285
nighthawk285 is offline
Also, if you check out ACDelco and Motorcraft Auto Parts OE Parts Headquarters -, you can get Motorcraft parts at A LOT cheaper prices, and they are all genuine.....saved me a TON of money when I did me tune up/replaced random parts...
Old 07-08-2010, 01:25 AM
CHELLIE's Avatar
CHELLIE
CHELLIE is offline
Parts sold at NAPA are very high Quality, and very reasonable too, NAPA sponsors some of the NASCAR teams too.
NAPA Sponsorships
In 2010, NAPA will continue its long tradition of primary sponsorship in NASCAR, sponsoring Michael Waltrip Racing and the #56 Toyota Camry driven by Martin Truex, Jr. NAPA shares Toyota's enthusiasm for motorsports, and through its sponsorship support, looks for an exciting 2010 NASCAR Sprint Cup Season. NAPA remains a dominant player
Old 07-08-2010, 06:15 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
Borg Warner BWD is good too.
Old 07-08-2010, 07:36 AM
BigSix1's Avatar
BigSix1
BigSix1 is offline
Words Matter....
Uhm...cranking = "turning over"
So...I believe what you're trying to say is:
"My truck cranks, but refuses to FIRE."
Is that correct?
Old 07-08-2010, 11:12 AM
erica's Avatar
erica
erica is offline
Yea, meant to say "fire". At this point I am looking to replace the distributor cap and rotor. I've tested the spark plug wires and they are within the specified range.
Old 07-08-2010, 05:34 PM
95F350XL's Avatar
95F350XL
95F350XL is offline
Do you have fuel and spark?
Old 07-08-2010, 06:19 PM
erica's Avatar
erica
erica is offline
Yes, I have tested for fuel. Not sure how to test for spark.
Old 07-08-2010, 07:26 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
will it start with starting fluid?
if yes, and then stalls, fuel pump problem.
if no then no spark.
remove coil wire from dist. and ground it out and then crank, do you have spark there?
if you do then remove a plug wire and see if you have spark ther, remember to reconnect coil wire.
Old 07-08-2010, 07:39 PM
ymeski56's Avatar
ymeski56
ymeski56 is offline
Der Postmeister
NAPA Sponsorships
I've never been disappointed w/ NAPA. W/ prices either. Great source for RABS valves.
Old 07-09-2010, 04:23 PM
crazy4wdracer's Avatar
crazy4wdracer
crazy4wdracer is offline
+1 It depends a lot on what kind of parts you are buying too.
Quick Reply: What is 2nd best to Motorcraft parts?
