white smoke while driving
Old Jul 8, 2010 | 09:06 AM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
It's not quite that simple, but that's what an EGR bypass kit does. There are also kits available that delete the EGR system entirely.
If you have an EGR cooler problem you most likely have a bad oil cooler, and that will have to be replaced as well.
I think you should check for trouble codes that may be stored and monitor the coolant/oil temperatures under driving conditions to determine exactly what the problem is. If you don't have a way of doing that, a competent tech is well worth the money IMO.
Old Jul 8, 2010 | 09:44 AM
nagorg's Avatar
nagorg
any suggestions on a code reader i should buy?
Old Jul 8, 2010 | 10:00 AM
SteveBricks
FTE Emeritus
They're not all created equal, that's for sure....it'll need to be OBD2/CAN2 capable.
I know this one will do pretty much anything you'll ever need, including live data capture.
Riffraff Diesel: Total Ford Enhanced Bundle
No doubt you could get your truck diagnosed by a competent tech for a lot less money, but you'd have this for next time if needed.
Old Jul 16, 2010 | 11:03 AM
nagorg's Avatar
nagorg
So i know for sure that my egr cooler is not leaking, but every morning for the past week my truck runs ****ty(hard shifting have to let off acellerator to get it to shift and still some white smoke) but in the afternoon runs like a beast its like driving two different vehicles. any ideas?
Old Jul 17, 2010 | 07:57 AM
usmc161's Avatar
usmc161
Mine is doing the same thing and getting worse. I'm will accelerate to about 10 mph at 22oo rpm and stay there. When I let of the tranny shift hard into second and then it accelerates and gets stuck again before slamming into third. But once I come to a stop or the truck warms up a little it runs normal. I can't figure this one out. This all started a couple of days ago.
Old Jul 17, 2010 | 08:03 AM
npccpartsman's Avatar
npccpartsman
Sounds like you might have some injectors going south. Try letting the truck warm up a significant amount before you drive it and see if it still does the same thing with the trans. If you're having a problem with the white smoke you need to check to see if it smells sweet (coolant) or like unburnt diesel.
Old Jul 18, 2010 | 05:58 PM
nagorg's Avatar
nagorg
If i let it warm up for 5 to 10 minutes then it runs like a champ and it does not smell sweet.
BigBlackF-250
24
May 5, 2016 11:02 AM
dynarider33
6.4L Power Stroke Diesel
Nov 11, 2015 05:23 AM
breedo99
Aug 17, 2015 02:23 AM
fatkid89704
Jun 15, 2014 10:22 PM
Regulator1988
Jan 8, 2013 05:30 PM
