Temperature gauge
Old Jul 5, 2010 | 08:29 PM
HD74's Avatar
HD74
Temperature gauge
My gauge and or sending units started acting up. The gauge was not give the correct temp reading. So I checked the sending units first and noted the single post sending units post was loose. So ordered replacements for both sides. So replaced the single post unit first to see the results before making any other changes. Now the gauge needle sweep to almost cold than as the engine warms up the needle moves to Hot. By this time the engine is at normal operating temperature. Next step was to replace the dual post unit, with the same results as above. So is there an adjustment that can be made to the gauge? What do you all think?
Thanks Marty
Old Jul 5, 2010 | 10:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
How are you running the gauges on 12v; Runtz, CVR, or?
Old Jul 5, 2010 | 11:45 PM
HD74's Avatar
HD74
12v, runtz
Old Jul 6, 2010 | 07:31 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Could be a bad Runtz, if you can switch with a different one that would be a good test. I don't know a bad one would behave like that tho. I don't think a bad gauge would do that either. Do you have a mech gauge to check that it isn't reading correctly for some reason? Like if a thermostat was sticking?
Old Jul 6, 2010 | 10:59 AM
HD74's Avatar
HD74
I've checked (with infrared thermometer) to make sure everything and both heads read (165) with in a few degree of each other.
Old Jul 6, 2010 | 11:27 AM
Julies Cool F1's Avatar
Julies Cool F1
This post has been deleted at posters discretion.
Marty, contact me off line.
Old Jul 7, 2010 | 12:31 PM
HD74's Avatar
HD74
Will do, by email.
NLPRacing
29
Nov 7, 2015 05:46 PM
Grinder Man
Oct 10, 2014 09:35 AM
Steel Toy
Vehicles for Sale
May 9, 2014 07:46 AM
Tyrboss01
Oct 9, 2012 04:11 PM
blong
Jul 19, 2011 07:57 PM
