Trans id help
Old Feb 9, 2003 | 08:46 AM
ridgerider3's Avatar
ridgerider3
Unhappy Trans id help
This is the tag off of my trans. Can any 1 help me figure out excatly what it is?
RTS AB1{I} ME2
E4TR BA 0541
Was told when I bought it that it was a SROD. It does not look anything like what few pictures I have seen. It is an Alum case.
Old Feb 9, 2003 | 01:56 PM
FordPerf300's Avatar
FordPerf300
Trans id help
What year truck, the only 2 aluminum trannies i know of are the ZF and the M5OD.
Old Feb 9, 2003 | 02:10 PM
StrangeRanger's Avatar
StrangeRanger
Trans id help
The SROD and TMOD are also aluminum cased, as is the NP435. There may be others as well. I'm assuming it's a 4 speed, since it's supposed to be an SROD. Since you don't mention a non-synch granny 1st, I'll assume it's not an NP435. If the shift lever comes out of the top cover it's a TMOD. If the shift lever comes up off the tailshaft housing with an external link running forward to the tranny housing, it's an SROD.
Old Feb 9, 2003 | 03:14 PM
ridgerider3
Trans id help
What year the tranny is, I have no idea as I bought it at a junk yard to be part of the replacement of the 232 v-6 and "three on the tree". {Fords better idea to get decent fuel miliage out of a F-100} The shifter does come out of the top, so that is a big help. Know I have an idea of what to look for when I go looking for a new shifter, as this one sheared off [outside the top portion].
Old Feb 9, 2003 | 04:14 PM
ridgerider3
Talking Trans id help
I have, after looking thru search engines 6 ways to next year, id'd the tranny as an "RTS" 3 speed with overdrive, years 78-87. Now all I have to do is find a "shifter", and i'm back on the road!
Old Feb 9, 2003 | 04:51 PM
StrangeRanger
Trans id help
Does this help?
http://www.motivegear.com/tech_info/...nny_guide.html
or this?
http://www.4speeds.com/toploader.html
Old Feb 10, 2003 | 09:46 AM
ridgerider3
Trans id help
They help some. Thanks.
Old Feb 10, 2003 | 01:40 PM
Brian460's Avatar
Brian460
Trans id help
Just for the info a N.P. 435 has a cast iron case with an aluminum top cover.
