98 expo driver window
Old Jul 5, 2010 | 05:18 PM
wildtwinkys's Avatar
wildtwinkys
hello im new to this site and hav a crazy problem.. my drivers window in my 98 expo wont roll up or downbut all the other ones do. but when i open the door it works fine.. shut the door and the window does nothing. i have never seen anything like this. any help would be great..
Old Jul 5, 2010 | 06:13 PM
alloro's Avatar
alloro
Maybe it's a loss of ground issue and it's only getting a good enough ground when the door's weight is on the hinges. Just a thought.
Old Jul 5, 2010 | 08:17 PM
wildtwinkys
thats a pretty good thought..
Old Jul 5, 2010 | 09:05 PM
alloro's Avatar
alloro
I spoke too soon. I just had a chance to look over the power window wiring diagram and all 4 window motors get the +12v and -12v from the driver's switch. So if it were a loss of ground all windows would be affected. After reviewing the diagram, I'd have to say there's more likely a chance of a broken wire running out to the door that is flexing as you open and close the door.
I'm attaching a PDF of the wiring diagram which I'm sure you'll end up needing.
File Type: pdf
Old Jul 6, 2010 | 06:46 AM
wildtwinkys
thanks man ill look into it..
Old Jul 15, 2010 | 07:33 PM
wildtwinkys
i really have not had a chance to look at this yet but got 1 more note.. when i push the window button the relay clicks. bad relay maybe?
stucky
Dec 19, 2007 10:16 PM
Brandon318
Dec 14, 2004 01:58 PM
rangedog
Oil & Lubrication
23
Mar 1, 2004 11:51 AM
MikeCT
Sep 25, 2003 11:43 AM
rmatejczyk
Aug 6, 2003 09:42 AM
