Center cap problem - 2001 wheels on 2000
Old Jul 15, 2010 | 10:36 AM
eb20004x4's Avatar
eb20004x4
OK, I did enough research to see that a 2001 factory wheel with 14mm was fine to run on my truck with 12mm studs since they are hub-centric. (I bought a set of 10 spokes to replace my chrome wheels that were starting to peel.) They look great and run straight and true. The problem is that the center cap will not grab and stay on. I am guessing that this is because either the lug is too narrow or too short. Is that right? If so, I think they made this wheel prior to changing the lug size so I could maybe buy new center caps to fit the 12mm lugs. Does anyone know if there was a 12mm 10 spoke alloy (1999 maybe)? If not, can the studs be changed easily? Is there another work around?
Thanks in advance and I apologize if my search missed finding the answer in a previous thread.
Old Jul 15, 2010 | 10:35 PM
Moto Mel's Avatar
Moto Mel
In 1999/2000 Ford started changing the lug studs to a larger more coarse thread and went away from the chamfered holes in the wheels and went with a more precise fitting stud and stud hole in the wheel with a flat washer mounted on the lug nuts. I think there may be a mismatch in that area or the spring clamps in the cover have been spread too far apart to grip the nuts. A pair of channel locks or pliers might cure your problem.
Gage2502
Feb 2, 2017 03:30 PM
tj90
1997 - 2003 F150
Dec 14, 2010 07:41 AM
wgotthardt
1997 - 2003 F150
Dec 17, 2005 07:17 PM
EpicCowlick
Jun 5, 2004 06:26 PM
