ok well long story short my brother abuses everything he gets his mits on, this time it so happens to be my parents 1995 F-150 Eddie Bauer Edition. He ended up punching the dash above the radio and cracked the portion of the dash just above the radio that runs down the passenger side.
Im looking for a junk yard replacement as LMC doesnt have the part, how is this piece attached and how do i remove it?
You will need to remove your radio and the glove box door which will allow you to access the seven nuts that hold the dash pad to the dash. The hard ones are the three that are located around the radio opening. It requires a 10mm socket and I use a 1/4 drive ratchet. It pays to have small hands as well!
I bought one for my sons truck at the local pull a part for 9 bucks. Used a round 1/4 "fingertip" ratchet I bought at the local parts store that proved to be worth its weight in gold when it came to those three nuts around the radio.
