300 EFI distributor control module ?
Old Jul 5, 2010 | 03:08 PM
Econoline 150's Avatar
Econoline 150
My 91 300 sometimes "bucks" at low rpm while accelrating. Does anyone think it could be the Distributor control module (mounted on the side of the dist) or do they just go bad and stop working altogether ?
Old Jul 5, 2010 | 03:39 PM
Harte3's Avatar
Harte3
I have read that they can start going bad and cause problems without even throwing a code.
Old Jul 6, 2010 | 09:48 AM
Econoline 150
I think you read right, it's not giving a code.
Hate to go out and buy a $80-100 part to find out it aint the problem.
Old Jul 6, 2010 | 06:13 PM
Harte3's Avatar
Harte3
If it were a carby engine I would say look to the EGR as being bad but it's EFI...a bit too techno for this old flatulence.
Old Jul 6, 2010 | 07:57 PM
Econoline 150
That's why I'm a askin
Old Jul 6, 2010 | 10:51 PM
Wyowanderer's Avatar
Wyowanderer
BEFORE you spend a cent, stroll down to your local Auto Zone/Advance Auto/ O'reilleys and ask them to pull the codes. They'll do it for free. You can even buy a code reader for 50-100 bucks and do it yourself.
I doubt the dizzy module is to blame; you'll just spend $$$$ until you know what code it's throwing.
Good luck.
Frank
Old Jul 6, 2010 | 11:31 PM
Roader's Avatar
Roader
X2. Pull the vacuum line off the EGR valve, plug the line, and see if the problem goes away. Make a restrictor plate if it fixes the problem and put the EGR vacuum line back on. It worked on my 300 EFI.
Old Jul 7, 2010 | 07:55 PM
chrlsful's Avatar
chrlsful
Hi Bill, good to see you again.
Has that E250 got OBDI? It will not tell you anything but "It works"/OR/ "It don't work (or is missing)". Even THAT is something to wrk with. You'll hafta do it the old way as above. How bout takin it off n see if that changes anything and what/where?
xtal_01
Sep 13, 2014 12:42 AM
raven3
Apr 9, 2014 12:17 AM
brentak
Oct 10, 2011 06:53 AM
Ranger GT2
Electrical Systems/Wiring
Nov 20, 2007 11:54 AM
hotrod
Oct 17, 2000 09:52 PM
