Towing capacity
Old Jul 5, 2010 | 12:01 PM
roadkingfl's Avatar
roadkingfl
Towing capacity
I'm looking at buying a Open Range travel trailer. I will also carry a motorcycle in the bed of the truck while pulling the trailer. Travel Trailer specs: GVWR 10,400 lbs., UVW 7,842 lbs., DRY HITCH WEIGHT 780., DRY AXLE WEIGHT 7,060 lbs., GROSS NCC 2,560 lbs. Motorcycle weighs around 850 lbs.
The truck is a 2011 F350 6.7, SRW, LB, CC, 4x4, 3.31.
Will I be OK doing this, or is it too much weight when going up and down mountains.
Old Jul 5, 2010 | 02:00 PM
smlford's Avatar
smlford
Look in you owners manual to be sure but my 2006, 6.0 can haul that with no problem so I assume you could too.
You'll need a weight distribution hitch.
Old Jul 5, 2010 | 03:47 PM
senix's Avatar
senix
you will be just fine. you will not even know it is back there.
Old Jul 5, 2010 | 04:38 PM
Rafiki2cu's Avatar
Rafiki2cu
Conventional towing 14,000/fithe wheel 15,800 according to the technical specs in my brochure. You will be fine.
Old Jul 5, 2010 | 04:55 PM
roadkingfl's Avatar
roadkingfl
Thanks for the help guys.........
Old Jul 6, 2010 | 09:04 AM
rickatic's Avatar
rickatic
The truck in my sig is rated to 23500 GCVW and yanks my 13000 pound fiver like it is not back there. Last leg of a 1000 mile weekend return home yielded 12.5 mpg.
Old Jul 6, 2010 | 09:26 AM
Rafiki2cu's Avatar
Rafiki2cu
The 12.5 mpg was that towing your fiver,if so what are you getting empty
Old Jul 7, 2010 | 01:51 PM
rickatic's Avatar
rickatic
I just ran a half tank or so through the truck without the trailer. In a 100 mile trip back from my fiver dealer, mostly highway with about 20 miles of city I showed 20.4 when I filled up. Today I ran around town doing errands, all city driving. The truck computer shows 19 right now. I hand calculated the first 4 fill ups and compared them to the computer. The results were too close to worry about hand calculations. It was never off more than a couple of tenths. The more I drive it the better it gets.
Old Jul 7, 2010 | 03:12 PM
fzrider998's Avatar
fzrider998
Just curious what your rear diff ratio is? That's great mileage...25% better than my F150 5.4.
Alanok
1947 and Older Ford Trucks
21
Jun 30, 2016 05:51 AM
Alanok
1966 - 1977 Early Broncos
17
Nov 24, 2012 07:40 AM
jimmyq2
All Things Towing
Oct 31, 2005 10:17 AM
