Tach install question
Old Jul 5, 2010 | 09:12 AM
jmilaman's Avatar
jmilaman
86 f150 XLT Lariat 4x4 302 efi aod
My truck does not have a factory tach installed. If I find a factory instrument cluster with a tach, can I put that tach in my cluster and it work. Kinda like plug-n-play??
Old Jul 5, 2010 | 09:24 AM
Rogue_Wulff's Avatar
Rogue_Wulff
It's not as easy as just putting the tach in your cluster.
If you have full guages, and find another full guage cluster with a tach, it will swap in.
The tach itself won't go into your cluster without changing the printed circuit.
There is one year (1980) that has a different wiring on the circuit, but it's easy to ID, as it's red and the 81-86 had a green one.
If you have oil and alt lights, rather than guages, you would need to find a cluster that has these lights as well as a tach.
Old Jul 5, 2010 | 10:03 AM
ctubutis's Avatar
ctubutis
I'm pretty sure 80 was green and 81-86 are red... I have craploads of red ones in my garage and
-0- green ones.
IIRC there might also need to be wires run from the ignition module area and either to the coil or
to the dash, I forget what I've seen not having been installed by default.
If you have idiot lights, yeah, good luck, the wiring is entirely different than for gauges.
Old Jul 5, 2010 | 10:06 AM
Rogue_Wulff
D'OH, you're right. 80 is green, and the rest are red. I was still waiting on my coffee to finish brewing.........
At least I got the rest pretty much correct, and did make mention that the wiring was different between the 2 colors.
Old Jul 5, 2010 | 10:52 AM
jmilaman's Avatar
jmilaman
Thanks guys, you rock!
Old Jul 5, 2010 | 11:07 AM
JimsRebel's Avatar
JimsRebel
good info at this link
https://www.ford-trucks.com/forums/9...-question.html
Old Jul 5, 2010 | 11:15 AM
Rogue_Wulff
Originally Posted by JimsRebel
That particular thread is one of the most complete and accurate compilations of info concerning installing the factory tach in these trucks.
The fact that I just happened to have started it was totally accidental, but at least it has *nearly* any question that could pop up already answered.
Old Jul 5, 2010 | 11:25 AM
Holmesuser01's Avatar
Holmesuser01
I installed a tach into my non-tach gauge package. It fits, and is hard-wired into the circuit.
I need another tach, as this one occasionally stops working, especially in cold weather.
