300 inline 6, 5 speed trans conversion
Old Jul 4, 2010 | 11:30 PM
olfordsnstone's Avatar
olfordsnstone
A friend of mine asked me to post a question on FTE, of whether there is a 5 speed manual transmission that will easily swap into to his 1970 F250 4x4 with a 300 inline 6. If anyone has any information on this type of swap, please offer your knowledge. He says he wants to try and improve his fuel economy.
Thanks, T
Old Jul 4, 2010 | 11:32 PM
Ford_Six's Avatar
Ford_Six
Not too easily, but an earlier ZF with an external slave might work. You may be able to convert that to work with the push rod linkage, otherwise you could add a hydraulic clutch to the truck's firewall.
Old Jul 5, 2010 | 04:42 AM
xstrange's Avatar
xstrange
I'd have to question if it would even be worth the trouble. If you got the 5-speed in there, what you'd be doing is lowering the engine rpm from, say, 3000 to 2400 rpm at highway speed. But you'd still be pushing the same big, heavy brick with the 4WD drivetrain drag, using the same long-stroke six cylinder. I doubt that the mileage would be significantly different carrying the same load at the lower rpm. It might even be worse.
Old Jul 6, 2010 | 11:08 PM
olfordsnstone
Yikes... That doesn't sound too encouraging. I'll pass that on to him. Thanks for the replies guys.
Tim
Old Aug 26, 2010 | 10:07 PM
F-250 restorer's Avatar
F-250 restorer
You are not correct there. The 300's torque curve begins at a much lower rpm than 99% of the v8's. By putting in a ZF 5 sp., you'd be lowering the rpm's on the freeway by about 25%, from 2400 rpm, let's say, to 1800 rpm, thereby boosting your mpg considerably. And 1800 rpm is right in the prime rpm's for a 300, a low rpm tractor engine.
BTW, Ford did put the ZF behind the EFI 4.9 (300), and it is much sought after conversion.
Old Oct 3, 2010 | 09:43 PM
young rodder's Avatar
young rodder
the mustang borg warner T5 was a good conversion for my friend he has a 68 bump but rides along in the slick forum slick60's.com unfortunatly for me i cant remember his screen name right now
Old Oct 4, 2010 | 11:04 AM
crazed87bronco's Avatar
crazed87bronco
how good is this T5 trans? ive heard they easily break with any beating of the truck because the truck weighs so much and the trans can't handle it. ill be looking for a 5 speed swap myself next year hopfully so any help will be great
Old Oct 4, 2010 | 10:29 PM
RichS2659's Avatar
RichS2659
They are utterly worthless for a 4wd application as 1st is somewhere around 3.0:1. Depending on the engine chosen, look for a ZF, NV-4500, and at the least is the MR Mazda 5 spd found in F-150's. I think that there are kits to put NV-3500 (?model) trans in Broncos, so they could be used also, maybe. If you have an FE, I think you are stuck using the NV trans as they can be had with an adapter bell housing specially made for the FE.
Old Oct 4, 2010 | 10:57 PM
crazed87bronco
Sorry for asking a dumb question but I'm not to familiar with the zf nv-4500 trans can anyone give me the rundown on this trans
Old Oct 5, 2010 | 01:56 AM
F-250 restorer
The NV is a dodge 5sp od trans. Supposedly it is about the strongest of the 5sp trans. IIRC, it has a granny 1st like the ZF. However, to use on a Ford engine you need an adapter from the aftermarket. Because of that, and because the ZF is plenty strong and bolt to most Ford engines w/o adapter, most guys use the ZF.
4wd ZF's are a bit pricey--6--$800 range for a used one, and the 2wd's can be found for 2--$400. Ford put the ZF on F250's up.
Old Oct 5, 2010 | 03:02 AM
crazed87bronco
What is the NV's and ZF's 4x4 5th gear ratio? And when did they start using these in fords and dodges? I'm guessing these are hydraulic clutches? What is all needed to put one of these trans in a 71 f250 4x4?
Old Oct 5, 2010 | 11:58 AM
F-250 restorer
Do some research. That way you know the answers are accurate.
Old Mar 11, 2012 | 08:05 PM
jehuck's Avatar
jehuck
So will the zf 5 speed bolt right up to the 1979 300 six cylinder or do you have to make changes
Old Mar 16, 2012 | 12:32 AM
401477534's Avatar
401477534
Pretty well doable, especially with the divorced t-case...My brother has a 77 highboy with a 300 6, We bout a 2wd zf5 speed for it. The plan was to take the old trans out, slide the new one in, mount up a slave cylinder for the clutch, shorten the intermediate drive shaft about 2 inches, or whatever it needs, and then fabricate a bracket to hold the t-case shift lever. and then add the turbo
Old Mar 16, 2012 | 12:35 AM
401477534's Avatar
401477534
also, you will want a small block zf5, 1st 5.72 2nd 2.94 3rd 1.61 4th 1 5th .76
with 4:10 gears and 31.5 inch tires 235 85 16 you will turn about 2200 rpm at 65 mph vs about 2900 rpm with a 4 speed
RPM / Speed / Gear Ratio Visual Calc
BiltFordTuff
Jan 4, 2020 09:24 PM
m55m
Engine Swaps
May 24, 2016 03:07 PM
Chewy1978
Sep 22, 2015 01:17 PM
Michael Sizemore
May 7, 2014 09:53 AM
300FOREVER
Mar 30, 2010 11:37 PM
