The price seems great. Don't plan on putting many miles on the truck and looking at options. If you don't used these, what brands have people had good luck with?
Thanks all.
The e-bay item is a wheel bearing and hub assy. as redford has clarified.
This doesn't match your post "title" and the item he shows is the best money can buy. Probably a bit more than the e-bay item but completely different.
OK, I made a mistake. I believe my bearing/ hub assy is going out. I know they run from $250 ++ so this seems very low. I don't put a ton of miles on the truck so thinking of trying these low priced ones. Just checking to see if anyone else out there have tried them.
Sorry for the mistake in the title.
Stephie
if you want the best for your truck, go with timken.
I, however, needed a wheel bearing and didn't have $250 so i bought the ebay brand similar to what you posted. It has worked perfectly for the last 5k miles... It looked like a good solid piece of hardware, i couldn't tell the difference between it and the ford part i removed (other than it wasn't warn out and rusty).
Good luck!
Just make sure you get the right one (fine/course threads)
Thanks Gunnerdog. A couple of questions for you then. Do you know the seller that you got yours from? What do I need to look at to tell if I have fine or course threads? The seller of the one I am looking at had this to say about his:
"it our brand.
we buy from factory,
same factory, as timken, BCA, national,
all have the same bearing, different names,
ours has a 1 year warranty
thanks mike"
If I planed on driving the truck more, I would go name brand but don't plan on it so at this time, I am thinking of getting a pair of his.
Thanks again for the help.
I have used these on my truck. In fact I only needed to replace the abs sensor on one side, and for cheaper than than one sensor I just replaced the whole bearing assembly. Even did both sides just for the heck of it, well really cuz the cheap price.
You should replace the rubber o rings/seals while your in there and will need to get the package of 4 studs to put the new assembly back on. You could probably take off the old ones, but again cheap parts, and better to go new. You can get the part #'s from guzzle's web site under needle bearing lube, http://www.guzzle7pt3.com/nblube.php, on top of directions to do the work. Your 01 should have the course studs, so you should be good there. They new bearing hubs come greased, but you may want to add more. I service my brakes, hubs 2 a yr, I know over kill but I do alot of water crossings to go fishin and while apart after a few months use the grease seemed to be running out, more from lesser quality than anything else, IMO.
I have close to a year now on them and no problems.
Well with the ball joints you have to take all the same stuff apart. The only things left really are the stub axle and the knuckle that the joints are on. Might be a hood time to do all at once so you don't have to take it all apart again when you change them, but up to you. Good luck either way.
Stephie
You didn't make a mistake. There are wheel hubs and locking hubs, and the terms are thrown around loosly because they are both hubs. (fault of whoever named them). I have heard no bad reports on those ebay hubs and notice the high feedback score he has. They used coarse threads on the 8 lug studs until about 2002. You won't need those new 4 hub studs that go through the knuckle unless you have trouble getting the wheel hub out and the new wheel hub doesn't come with them. Mine slid right out. Don't forget you can grease the hubs through the abs hole. (I did a write-up on it with pics.)
I need to do the wheel bearing on my truck too. Pissed because I just had a shop do the ball joints and they were idiots and didn't bother checking this.
So how do I figure out if I need coarse or fine threads?
EDIT: n00b to FTE, but on PSO and PSN, haven't updated my profile yet.
I've got a '99 F250 7.3L Diesel 4x4 with aftermarket Warn Manual Locking Hubs.
99 through 02 takes the coarse threads on the 8 lug studs. Maybe to '03.
I bought the Ebay unit bearings. They where made in china. The needle bearings failed in less that 10k and I greased them well upon install. Save your self the trouble and buy the real thing. A bad needle bearing can ruin the stub shaft very quickly
