1966 - 1977 Early Broncos
Headliner?
Old Feb 8, 2003 | 10:35 PM
Mike W's Avatar
Mike W
Headliner?
Has anyone made a new headliner? I am considering different options for replacing the headliner. Any input appreciated.
Old Feb 9, 2003 | 12:08 AM
Like M. Fords's Avatar
Like M. Fords
Headliner?
The previous owner of my '72 used a **** carpet.
I suppose if the color was right, it wouldn't look too bad. Just take the Hoover to it when it gets dirty!
Old Feb 9, 2003 | 12:15 AM
steve83's Avatar
steve83
Headliner?
In this '75, I used color-matched Rhino. This '77 still has the original, which just looks like cardboard with shelf paper stuck to it.
Old Feb 9, 2003 | 11:16 AM
Mike W's Avatar
Mike W
Headliner?
Nice photo's Steve. I am thinking of using some of those shiny panels used for a shower wall, believe that is what is is used for. Comes in 4x8 sheets. I think I would go for 3 pieces to make the back part easier to install. It should bend ok to match the roof and leave room for insulation. The old cardboard one is warped and cracking.
Old Feb 9, 2003 | 12:34 PM
steve83's Avatar
steve83
Headliner?
Sounds like it'll last, but it'll be noisy unless you a) use some spray adhesive to attach carpet foam to the back of it; b) undercoat the back; c) Rhino-line the back; d) apply Dynamat to the back. A hairdryer or heat gun will let you put the proper contour on it. For a long, straight, smooth bend, get a REALLY long piece of 3" copper tubing and put a blowtorch in the far end. Lay the plastic over it away from the torch and let it fall across the curve of the tubing wall.
1978crewcab
36
Dec 31, 2021 11:33 AM
LeviD
19
Oct 20, 2018 09:30 AM
kh0432
Oct 26, 2016 09:41 AM
ahall1
Ford Truck Parts for Sale
May 10, 2016 05:44 AM
1954_NJ_F100
Mar 15, 2016 03:59 PM
