crapy idle
Old Jul 4, 2010 | 02:08 AM
iduger's Avatar
iduger
crapy idle
I had oil changed today and truck started idling rough, are these two connected ?
Old Jul 4, 2010 | 05:51 AM
bismic's Avatar
bismic
What oil was used?
Did you check the fill level?
What filter was used?
Any DTC's?
Old Jul 4, 2010 | 09:46 PM
iduger's Avatar
iduger
I used rotella 15-40 and i think the filter was fram. I had some one else do it and the fill level was too high. Removed oil to proper level idle improved but not like it was before. Thanks for any help.
Old Jul 4, 2010 | 11:34 PM
bismic's Avatar
bismic
You need to be sure of the type of filter. The wrong kind can cause problems. So can the wrong oil and being overfull.
Some frams have been observed to NOT be the same as the OEM filter, but it may have been that someone switched filters in the box at the store.
Did you check to see if there were any codes (DTC's)?
rabidranger
Dec 5, 2002 10:37 AM
dvlinnell
Apr 16, 2002 11:29 PM
tomucen
Aerostar
Jan 8, 2002 10:11 AM
georgedavila
1978 - 1996 Big Bronco
Sep 18, 2001 07:54 PM
robie
Jul 18, 2000 09:46 PM
