Best 302 V-8 headers?
Old Feb 8, 2003 | 09:38 PM
Matt67's Avatar
Matt67
Talking Best 302 V-8 headers?
I'm sure somebody has already put headers on a 67-72 F-100 in here. I want to know what brand would last long and needs little or no modifications to get them in. I've heard lots of storys were guys have to bend, cut, etc. to get a new pair of (custom fit) headers into there truck.
Right now I'm looking at brands:
Hedman headers. $129.00
Dynomax headers. $99.95
Summit Racing headers. $79.95
Old Feb 9, 2003 | 05:00 PM
fordxxx's Avatar
fordxxx
I put Flowtech headers on my '72 302 about a year ago. They are a cheap header and a real struggle to put on. I just about gave up but I finally got them in. Things I had to do to get them in:
-jacked up my engine on the passenger side to get header in
-wrapped my starter with insulated wrap
-put shims under my motor mounts on both sides to get collectors off cross-member
-fixed fan shroud that I broke when I jacked up engine
-built new transmission cross-member because collector ended up pointing right at middle of old crossmember from about 1' away. New cross-member allows a straight pipe to back.
-put the automatic shifter rod into the transmission lever from opposite side and bent rod to clear driver side collector.
Once I did all that they worked OK. I have had no problems with leaking at gaskets. I've heard Hookers fit right but they cost way more.
Old Feb 9, 2003 | 05:39 PM
stroker393's Avatar
stroker393
Keep an eye on Ebay. There was someone awhile back that was selling a new set of Hooker Super comps for your application. I went with Hooker on my 69 but had to do alot of modifactions because of the 351W (393 stroker) but am very pleased with the outcome. The Hooker sound in my opinion is second to none.
Old Feb 9, 2003 | 07:13 PM
robertskunfused's Avatar
robertskunfused
as far as headers go stan's are probaly the best. on my car i run dynomax and they seal once and when you replace the gaskets they are hard to reseal. but as for the three you listed hedman would be the best, but with header the more expansive they are, the better they probaly are.
Old Feb 11, 2003 | 10:50 AM
tapenick's Avatar
tapenick
Wow. I would not have expected that many modifications to install headers. Anyone know of a manufacturer that makes an actual bolt on set? I checked Stan's, doesn't appear to make a set for the 302.
Tom
Old Feb 11, 2003 | 11:22 AM
Dave-ceedot's Avatar
Dave-ceedot
Hedman makes them. You can get the heavy duty ones that are thicker so they warp less and are ceramic metalic coated. They have a lifetime warrantee.
The normal ones are p/n 89150
The website is www.hedman.com
Old Feb 13, 2003 | 11:43 AM
71swissaqua's Avatar
71swissaqua
Hey Stroker393, what kind of modifications did you have to do to get your headers to work with the 351? I've tried Hedman and Dynoteck and can't seem to get even close. I have a 71 with a 351W abd a C-6. I've since about given up but it sure would be nice to figure out how to do it with out cutting up my truck. Do you have any pictures of it.
Clint
Old Feb 13, 2003 | 04:58 PM
stroker393's Avatar
stroker393
Clint
I know your pain well; I tried at least (5) different brands, from shorties to long tubes with no luck. The Hooker super comps were purchased off Ebay at a steal - #6826-1, 69-79 with 302. I wasn't going to cut up my truck so I had two choices; have a set made or alter the Hookers. Altering them was cheaper as my painter builds race cars and had plenty of spare header tubing laying around. The driver's side front (2) tubes had to be shorten to clear the steering box and the #2 tube on the passenger's side had to be cut out and replaced with a different angle tube to clear the frame rail. Also the collector ends didn't clear the cross member that is under the bellhousing / rear oil pan area but I'm running a 4-speed so I removed it. When this cold weather gets out of here I will update my pic gallery from front to rear with this three year project that is 99.9% complete.
Glenn54
23
Jan 28, 2017 11:38 AM
dbyrd342
27
Jul 21, 2016 07:33 PM
351Cleveland C4
17
Feb 7, 2015 10:49 PM
Nseal1996
Apr 2, 2013 12:12 AM
fordranger68
Exhaust Systems
Mar 2, 2004 03:02 AM
