Right turn clunk
Old Jul 5, 2010 | 12:26 AM
Peter94's Avatar
Peter94
Here is the KEY componenet. Your driveshaft DOES NOT CARE if the vehicle is turning right or left, neither does your transmission or your engine. Plus, Ryan, your not going to like me for saying this, but I believe you have "Staked" U joints on your truck. They are generally not serviceable. My 04 has them. Ford has a U joint service kit that they sell, which has a cutter that cuts the stakes off of the U joint, and then you can change it. But again, if it was a U joint, it would do it on right or left turns. I would be looking for something suspension related. Double check your sway bar end link nuts to make sure they did not loosen up on you. Same with your ball joints. I've seen it on numerous occasions (More so with the sway bar end links) that they were not tightened all they way down and move around.
Can you tell if the noise is coming from the front or rear of the vehicle? Which side? If it is front, like I said before, double check your nuts on your sway bar bolts/nuts. Make sure you use more than just your hand too. Because sometimes they can be just so tight you cant move it with your hand, but to the point where it moves when you are driving.
Old Jul 5, 2010 | 01:42 AM
Peter94's Avatar
Peter94
Just wanted to post a link I found of that U joint and tool. FORD F-150 U-JOINT UNIVERSAL JOINT NEW 2004-08: eBay Motors (item 120589362168 end time Jul-05-10 03:54:16 PDT) You can see the tool that you use to cut the stakes.
Old Jul 5, 2010 | 05:13 PM
Ryan50hrl's Avatar
Ryan50hrl
Staked joints changed in 06 or 07.....so mine are serviceable.......my current thought is the limited slip......its the only driveline...(and it is driveline noise)....part that may be affected differently by turning..... But then again i'm thinking i'll just put ujoints in as they've got 70,000 miles anyhow........the odd part is it only does it during the first upshift while turning right after stopping....
Old Jul 5, 2010 | 05:21 PM
Peter94's Avatar
Peter94
... while going uphill, wind from the south, between the hours of 10:00am and 2:00pm only on sundays it makes it.
The limited slip diff wont really make alot of noise, it will "shudder". You can feel it. I've never seen an l/s act up turning only one direction too. But who knows.
Old Jul 5, 2010 | 09:28 PM
Ryan50hrl's Avatar
Ryan50hrl
Well thats why i'm so confused.....as i've never seen anything driveline related that only happened turning right.............but...none the less its doing it....
Old Jul 5, 2010 | 09:31 PM
Peter94's Avatar
Peter94
Can you distinguish whether or not it is front or rear, or is it right or left.
Old Jul 5, 2010 | 09:35 PM
Ryan50hrl's Avatar
Ryan50hrl
Its middle to back......for sure not front
Old Jul 5, 2010 | 10:27 PM
Peter94's Avatar
Peter94
I would say first and foremost, check the obvious stuff. Make sure there is nothing rolling around your bed/back of your cab. Also check to make sure your spare tire is not bouncing around under there either. If all is well you should be able to crawl under there and feel around for loose parts. Possibly look at shock mounts, transmisison mount, sway bar links, and look at your sway bar mounts/links. Also take a look at your leaf springs and where they mount as well. I wish I could hear this noise.
Old Jul 5, 2010 | 10:41 PM
Ryan50hrl's Avatar
Ryan50hrl
Yep...tried all the obvious already......its time for fluid changes anyhow....so I guess i'll poke around in there while i'm doin it...
Old Jul 8, 2010 | 10:14 AM
Maniac01's Avatar
Maniac01
I had a similar issue. My truck would clunk when turning right at low speed when either going in forward or reverse. My issue was up front though and I could feel the clunk in the steering wheel. I had a cut cv joint sleeve that ruined the cv joint.
Old Jul 9, 2010 | 12:18 AM
Peter94's Avatar
Peter94
Ever find anything on this? Just curious...
Old Jul 9, 2010 | 05:33 PM
Ryan50hrl's Avatar
Ryan50hrl
Well....I changed the tranny fluid and transfer case today.....along with the rear diff....I've only drove 10 miles since but it seems to have disapeared.....I know for sure that none of them were low....i'll let ya know if it returns next time i take it for a drive...
Old Jul 12, 2010 | 08:42 PM
  #28
Ryan50hrl's Avatar
Ryan50hrl
Well.....200 miles and the clunk is gone.....just from fluid changes......not sure exactly what was causing it but its gone so i'm happy.......anyone else gets this it might be worth some fluid changes...
Old Jul 12, 2010 | 10:53 PM
  #29
Peter94's Avatar
Peter94
Lol that makes no sense! But hey, if your problem is gone more power to you. There are just some things in this world that dont add up, but somehow it all works out.
denny7170
Jul 3, 2016 09:38 PM
wprobasco
Mar 12, 2016 07:47 AM
tk1251k
Sep 11, 2008 01:36 PM
taxgod4u
Jul 3, 2008 10:28 AM
clevo351
Dec 2, 2005 12:28 PM
