compression tester(2)
Old Jul 1, 2010 | 12:00 AM
peruses's Avatar
peruses
anyone got a compression tester I could borrow anywher in NW oregon/SW washington?
I realy need to get compression numbers on my truck and it seems the cheap compresion testors from HF won't work
I wish I could drop $200 on a good kit right now but I either need to borrow one or find one for around $50 fittind for the older VW diesels would be helpfull too
Old Jul 1, 2010 | 12:38 AM
oreocreaming's Avatar
oreocreaming
there are a few auto parts places like autozone that have a tool rental setup. go in, pay for the tool, when you bring it back you get 100% of your money back. i would check that out bud.
Old Jul 1, 2010 | 12:42 AM
peruses's Avatar
peruses
humm I'll call round town see if any of em will do that
I doubt it though they kinda weird about that sort of thing in this neigborhood
Old Jul 1, 2010 | 01:00 AM
oreocreaming
well, they do it because if you dont bring it back, then the item is still paid for so its all ok to them.
Old Jul 1, 2010 | 01:04 AM
peruses's Avatar
peruses
yeah but the parts stores round here are afraid of ticking off the shops they supply by making it easier for folks not to go to them for simple crap, not one parts store in town will even lend a code reader
I could go on for a bit but I really am kinda bitter about it
Old Jul 1, 2010 | 08:19 AM
WarOzz's Avatar
WarOzz
Check with one of the major chain stores not the local style parts shop. The chain stores really don't care about local mechanics and most of them rent tools.
Old Jul 1, 2010 | 09:10 AM
fellro86's Avatar
fellro86
I know Autozone doe not have diesel compression testers, don't even have the regular compression testers on the loaner program. Harbor Freight has them for around $50 or less generally. They do cover anything with a glow plug for sure.
Old Jul 2, 2010 | 12:10 AM
damac's Avatar
damac
If you already have the necessary other stuff just laying around your garage, I would get the harbour freight kit.
I just happened to have solder supplies, simple propane torch, and an old glowplug.
I took my time by cutting off the valve on the supposed adaptor for our trucks. I then cut an old glowplug accordingly and soldered things together so it would thread in without bottoming out, etc. compared to an old glowplug depth.
It worked for me, did 2 runs and got the same results. I kept the tool in the drawer for later use just in case as well.
Now as far as actual readings compared to a "professional" gage I cannot vouch for, but my one experience showed everything looked alright.
Old Jul 2, 2010 | 07:43 AM
nappy nate's Avatar
nappy nate
Except a Ford IDI and a bunch of others. Been there done that and dont want to modify the tester in order to get it to "work" for me.
Old Jul 2, 2010 | 09:42 AM
fellro86's Avatar
fellro86
According to the case, it is supposed to do them. Good to know they are not exactly as presented. I had kicked around the idea of getting one, but hadn't really needed one.
Old Jul 2, 2010 | 10:25 AM
PLC7.3's Avatar
PLC7.3
If you get the HF tester try getting the adapter elsewhere.....
Diesel - Automotive Hand Tools & Equipment (Page 1 of 3)
Snapon..... adapter
Description:
For GM 4.3L and 5.7L plus Navistar 6.9L and 7.3L diesel engines. Replacement valve core is M3545A4. Must be used in conjunction with MT33C Compression Gauge and M3569 or M3570 Quick Couplers.
M3545B, Adaptor, Glow Plug Compression (for 6.9L diesel engines)
Star Products , TU-15-1A Diesel Adapter - Glow Plug - 10 x 1.0
Old Jul 2, 2010 | 12:08 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Well, mine from HF just showed up, it's a U.S. General #93644, It states in the parts list a M10x1 adapter is included, It's supposed to be adapter number 17 for the Ford/Navistar 6.9L - 7.3L up to 1994 ... I must be blind and dumb or they are!
There is an adapter that has the correct threads, however it is way to long to work.
The quick disconnect is unusual, finding adapters to fit is unlikely, however there is an 1/8" male pipe thread adapter with schrader, so adapting should be easy.
-Enjoy
fh : )_~
Old Jul 3, 2010 | 09:04 PM
peruses's Avatar
peruses
think I have it sorted out where I can
one of these
Star Products STR TU-15-1A - Diesel Adapter - M10 x 1.00 Glow Plug
and one of these
Star Products STR TU-15P - Diesel Compression Tester (No Case)
should do the trick for the ford right?
now I just need to find out what adapter I need for the 91 VW jetta diesel
Ford F834
Aug 9, 2014 10:08 PM
whittier97370
16
Feb 9, 2013 09:09 PM
Robert6401
Sep 22, 2010 07:15 PM
sstrunk
1983 - 2012 Ranger & B-Series
Mar 10, 2010 06:00 PM
alstieg
Oct 31, 2009 04:29 PM
