Sponsored by: Real Truck
Vibration Help!
Old Jun 30, 2010 | 07:56 AM
Buffalo250's Avatar
Buffalo250
Vibration Help!
Dealer can't seem to figure this one out. So I'm turning to the experts. When I turn from a stop left or right I get kind of a grinding vibration. Dealer said it was tires replaced them still there. It is not nearly as noticeable on wet pavement. The best way to describe it is it almost feels like you're in 4 wheel on drive pavement. But only does it when turning from a stop. If I'm moving and make a turn it's never there. I'm lost. Any thoughts? It's definitely in the front somewhere.
Old Jun 30, 2010 | 01:36 PM
mikesmayhem's Avatar
mikesmayhem
I was going to say it sounds exactly like a limited slip issue in the rear. Are you 100% that it is in the front?
Old Jun 30, 2010 | 07:05 PM
Buffalo250's Avatar
Buffalo250
Haha. Well I thought I was positive it was the front until you suggested the rear. Now I'm listening and feeling it and I'm second guessing myself. I definitely know it's not the tires. The dealer had said that was the issue and $900 later I know it's not. I had thought maybe a u-joint but haven't checked them yet. I've got another issue too I suppose could be related to the u-joints. Whenever I shift into reverse I got like a double clunk. I feel reverse engage and then it almost feels like it engages again. Had that happen on my GMC and it was a u-joint. They seem manifest themselves so many different ways. I appreciate anyones thoughts.
Old Jun 30, 2010 | 07:23 PM
sdetweil's Avatar
sdetweil
can you give us some more info on the truck... age, miles, ...
sam
Old Jun 30, 2010 | 07:25 PM
Buffalo250's Avatar
Buffalo250
07' F250 4x4 Ext cab gasser 88k.
Old Jun 30, 2010 | 08:04 PM
5.4f250sd's Avatar
5.4f250sd
Do you feel it in the seat of you pants coming up through the seat?
Old Jun 30, 2010 | 08:20 PM
Buffalo250's Avatar
Buffalo250
No I feel it only in the wheel. It does it regardless of how hard I accelerate but as soon as the wheel is straight it stops. Liek i said before when the road is wet I don't feel it. I'm lost here.
Old Jun 30, 2010 | 09:12 PM
5.4f250sd's Avatar
5.4f250sd
I get just a little chatter from my limited slip but it is in the seat of your pants. It could be you limited slip but i can't tell you that it is for sure.
Old Jun 30, 2010 | 09:18 PM
lakewood's Avatar
lakewood
what kind of tires do you have, i went from a/t's to m/t's and had a vibration at take-off after, i thought its was my drive-shaft/limited slip but i realized the ***** on the m/ts where causing it.
It could also be your spider gears, they only engage when you turn, if im correct?
Old Jun 30, 2010 | 09:52 PM
DAVE67FD's Avatar
DAVE67FD
My best guess would be front axle u-joint/s. Rear shaft joints or spline may need to be lubed, hence the noise backing up. Could be ball joints as well but would like to think dealer wouldn't miss that one.
Old Jul 1, 2010 | 04:23 AM
redford's Avatar
redford
FTE Leadership Emeritus
In addition, check your 4x4 hubs for binding or locking up and check your front brakes.
I doubt it is front drive shaft related as it isn't supposed to be spinning when you are in 2 wheel drive, unless your hubs are not freewheeling.
Also, find another service department.
Old Jul 7, 2010 | 06:50 PM
Buffalo250's Avatar
Buffalo250
Problem Solved?
Dealer just finished putting in new clutch packs. They claim that was the cause of the vibration. I'll let everyone know if that was it. Cost was $700 so I hope that's it.
billbaio
30
May 5, 2010 03:53 PM
SLE
Apr 22, 2010 04:14 PM
worknon10s
Apr 7, 2007 06:19 PM
ford8n47
Nov 12, 2006 06:00 PM
