Find any Dually lug nuts like these
I'll take 8 ... They take a 1-1/16" socket to get them off, they are supposed to be torqued to 140 ft lbs... Might be some work getting em off, Those are from a '91 F350.
Thanks ...
-Enjoy
fh : )_~
head to your local salvage yard and paw through their buckets.those are an easy score!
i had to keep weeding through those to find the next size up (99-02 SD) to fit my rear dually adapters.
found all but three.finally had to break down and just pay ford for the last 3.
Stock battery hold down brackets and hardware (nuts, bolts, clips, whatever else necessary)
Stock driver's side battery tray
XLT Lariat center dash panel that's not broken at the top. I believe it's black with wood grain.
Tailgate that's not destroyed.
A good 6.9L
Are you going to that huge junkyard in/outside Spokane? I bought my brother an entire leather interior for his grand cherokee for ~$100. There's nothing like that one around here.
id like to have the screw on bottom piece of that '94's fuel filters water separator.
(actually all i need is the drain/screw from it.i'll buy a new rubber washer for it.)
Core Support mounting hardware ... Cushions, Shims, Spacers, Washers, Bushings, etc...
The cushion condition is irrelevant, but I do need them, they have a steel bushing inside them I need! Bolts are not needed!
Same with cab mount hardware, regular or super cab, either will work.
I would supply an image of all the pieces if I had one or could get one, unfortunately whats left of mine can only be swept into a dust pan.
remember we cant talk money in here guys keep it all in pms or the thread may have to go away.technically your not suppose to sell in the forums but i am using my discretion and keeping it going because lemon is helping others out
Thanks for the reminder ... And I and I'm sure others appreciate your careful discretion.
I would hope IB would not have an issue with this unless of course it gets out of hand and $$$ numbers start popping up and peeps start posting items for sale.
Thats where your DELETE powers come in ...
Thanks Rupe for allowing this to go on, Appreciate it!
If it's not too much to ship it, I need a power mirror switch(92-96), and the plastic panel to cover it(92-96) and the power window switches, and an instrument cluster bezel for a 92-93(auto trans, no 4x4, no airbags, dual fuel tanks), and a bezel for an 80-86. Pictures to help ID the parts i need...\/
Similar to this.....^^, but with the added hole for the power mirror switch.
PM me a cost before you get the parts please, so i can make sure i can afford it and shipping.
-Enjoy
fh : )_~
they give me quite a bit of room to make my own decisions which is nice.that is until things go to hell.then i gotta be a jerk ,so im watching this thread pretty close.i doubt i have issues though you guys are typically self moderating
Mostly I go to Pull And Save, the self service yard. They don't inventory parts there, so you just have to see what you can find, and the parts are flat-rate no matter what they came out of.
Dually lug nuts, tailgates, other odds and ends, sure, I can probably find those. I'm not too sure what a vacuum fitting looks like but i'll keep my eye open.
But turbos go quick. And if I find one my own 6.9 would probably want it, haha.
-Matt
Hi Matt the vacuum restrictor fitting looks like a tube coupler, its blue or other colors, its at the top of the thermostate housing, it goes in between 2 hoses, it has a pin hole in it, to restrict the vacuum, if you cant find any, thats ok, i will just have to make one with a pin hole in it and paint it blue
VREST is a vacuum restriction.
The 3 port valve is located on the top of your thermostat housing.
You can see the yellow valve here, the little blue thing between the rubber fittings on top is the VREST.
Thank
the blue coupler, between the yellow vacuum valve and the red vacuum hose at the very top, just a little bit of the blue coupler is showing
