rear end weight...
Old Jun 29, 2010 | 09:55 PM
freakboy's Avatar
freakboy
rear end weight...
Hey guys... anyone have any idea on how much the rear end weighs on a 78 f150 with a inline six? i need to know aproximatly how much the rear weighs so i can order some coil overs for the rear... any help is apreciated... i cant weigh mine cause its just a frame and wheels and motor in my garage right now...
Old Jul 1, 2010 | 12:17 AM
freakboy's Avatar
freakboy
No one can help?
Old Jul 1, 2010 | 12:32 AM
Ace.'s Avatar
Ace.
the whole rear? as in bed, axle, wheels/tires, bumper, shocks,and frame? or just the 9'' rear axle?
Old Jul 1, 2010 | 12:35 AM
mikeo0o0o0's Avatar
mikeo0o0o0
You might take your curb weight if you know it and multiply by .4 This should get you close. For what you're doing you don't want to figure in the weight of the rear axle. Rear axle is unsprung weight.
Old Jul 1, 2010 | 12:40 AM
freakboy's Avatar
freakboy
I need all of it.. basicaly how much the rear end would be weighing if it were on oval track scales...
and thank you so much Mike! I have been trying to figure this out for a while.. just another quick question how did you come up with that equation?
Old Jul 1, 2010 | 04:04 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Go to a truck stop and get on the Cat scales. They will give you individual axle weights.
Old Jul 1, 2010 | 07:39 AM
freakboy's Avatar
freakboy
I would do that but i kinda cant... ummm lets just say the only thing on the frame is the motor....
Old Jul 1, 2010 | 09:04 AM
mikeo0o0o0's Avatar
mikeo0o0o0
This is just my "seat of the pants" equation. Like I said, it should get you close.
If you really want to split hairs, the weight bias on the rear axle is greater on a short bed than a long bed.
On a pickup most of the weight is located over the front axle. As you move the rear axle further away from the front axle, the center of gravity moves aft also, but not the same amount as you move the axle because the bulk of the weight (engine, cab, tranny, etc.) doesn't move rearward....oops, here I am going off on a tangent again, sorry.
Simple answer to your question, my equation is a "gut feeling".
Old Jul 1, 2010 | 12:25 PM
freakboy's Avatar
freakboy
alright... better then anything i guess... if need be i can always buy new coils later down the line... thanks for your help
Old Jul 1, 2010 | 12:38 PM
OrangeJuice's Avatar
OrangeJuice
I ran my 76 F-100 with a 390 over the local truck scales and the rear weighed about 1900+ LBS. Hope this helps.
OJ
Old Jul 1, 2010 | 01:32 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Empty weight 4500-5000 lbs (guess) X .4 = 1800-2000 lbs
actual scale weight~1900lbs
seat of the pants
Old Jul 1, 2010 | 01:55 PM
freakboy's Avatar
freakboy
Alright guys thanks so much!
tyhorn26
Jun 21, 2015 02:45 PM
coloradotrk
20
Oct 7, 2014 06:50 PM
GuitarJesus
33
Sep 19, 2014 04:07 PM
FarmBoyNation6.9
Large Truck
Jan 3, 2014 10:26 PM
EDMCCLOUGHLOCH
Flathead V8 & Flathead 6
Sep 22, 2005 09:27 AM
