Towing a fifth wheel
Old Jul 1, 2010 | 11:28 AM
tex25025's Avatar
tex25025
Originally Posted by mittsoff
Running synthetic is a good choice. Not only does it extend your service intervals, it also gets rid of heat better than 15/40. I worked for Esso for 3 years and have been to a few trade shows and all the oil geeks say the same thing.
Not only that but turbo shut down time after driving is much less of an issue then it was with pure dino oil.
Old Jul 1, 2010 | 11:30 AM
peteyx's Avatar
peteyx
One real simple, easy trick is to always use TOW/HAUL mode (when towing that is) on the end of your gear shift lever.
Old Jul 1, 2010 | 11:56 AM
Cowboy65's Avatar
Cowboy65
Agree
Not only does it extend your service intervals, ...
Disagree. I run synthetic but change it at 5K mile intervals which is actually 2.5K miles sooner than Ford recommends. Good, clean oil is particularly important to the 6 liter engine and IMO the additional cost is cheap insurance against oil related issues. Just my $0.02
Old Jul 1, 2010 | 12:09 PM
69cj's Avatar
69cj
I agree with cowboy on the clean oil aspect but also due to the fact that the 6.0's high press. oil system shears the oil. 5,000 miles/6 months is the limit that I will leave oil in and I also use the 5W40 synthetic.
Old Jul 1, 2010 | 02:38 PM
mohle's Avatar
mohle
Originally Posted by tex25025
Where are you seeing that, because according to my specs it's 18,000 for 5th wheel?
12,500 is where my little 2 horse gooseneck trailer maxs out(the one pictured with the tractor pulling it). That seems a little pathetic to me if that's the max tow rating.
The only thing that 12,500 could be a limit for is that would put me within 500lbs of the 26,000 weight would would be the max before needing a CDL(that would be "sticker" weight of both, not actual, however, "sticker" is what they go by if you don't have cat scale papers to show otherwise). Now there might be other exemptions that trump that weight limition(ag. products hauled within 150 mile radius from "home" etc), but that's if there is no other consideration, but weight.
Sorry, little disclaimer but that's conventional bumper pull towing. The limiting factor is actually the hitch. The factory Ford hitch is only rated for 12500 lbs. For 5th wheel towing, the numbers aren't all that impressive though. You may have a different configuration, but according to the GCWR ratings on pg. 16 of my Power Stroke Owners Supplement the GCWR of a 2006 F250/F350 SRW is 23000 lbs (all came with 3.73). If you have a DRW then it goes to 23500 lbs with 3.73 and 4.10's. 4.30 gears will get you the 26000 that you mention. The F450/550 is good for 26000 lbs unless you ordered the 4.88 gears with the high capacity trailer tow package. The max trailer weight is the GCWR minus the weight of you vehicle loaded up.
Old Jul 1, 2010 | 08:26 PM
tex25025's Avatar
tex25025
Ok, I gotcha now.
Old Jul 1, 2010 | 10:35 PM
albran's Avatar
albran
Originally Posted by 06truck ED
I have a bone stock 06 with the 5r11ow trans,what modifications should be done to my truck.I will start with an exhaust swap,egr delete?My truck has 22,000 miles on it.I will be purchasing a fifth wheel that could weight fully loaded maybe in the range of 14,000 lbs. Do you guys run 5w40 synthetic or 15w40 synthetic? Can you change back and forth or should I stick with one weight.Down the road I would like to install head studs for peace of mind. thanx for your imput Ed from Ohio but I really want to be from Colorado
The best bang for the buck ($00.00) has to be harpooning your tank, especially for towing.
Check this link https://www.ford-trucks.com/forums/2...-the-tank.html
ab
fridgeddiesel
18
Feb 9, 2016 12:34 AM
White Knight 2011
6.7L Power Stroke Diesel
Aug 28, 2011 11:36 AM
homeschoolin
Sep 2, 2007 05:00 PM
peppy
Oil & Lubrication
Oct 15, 2004 07:44 AM
Marky
All Things Towing
Sep 11, 2004 10:38 PM
