Loosen the lock screw, turn the adjusting nut with a 5/8 wrench. Clockwise lowers the float, counterclockwise raises the float. When you're to a satisfactory level, retighten the lock screw. You want fuel at the bottom edge of the sight hole. You may have a couple trips back and forth starting the rig to get her dialed in. You shouldn't adjust the nut more than a 1/4 turn at a time.
704 Dentside Man, I rebuilt my Holley 4180 and I was adjusting the secondary needle set and its leaking gas around the nut and the lock screw. Why would that be? Its like its under pressure unlike the primary gas never leaked out. All new parts too.
