Big Red is running rough
Old Jun 29, 2010 | 05:43 PM
NormF250's Avatar
NormF250
What does it mean when you plug the vacuum hose going into the vacuum advance module on the distributor with a golf tee and it runs fine...BUT...when you hook it back up it runs fine at idle but really rough when you excelerate?
Timing and points are set perfect.
I'm lost on this one.
NormF250
Old Jun 29, 2010 | 05:44 PM
NormF250's Avatar
NormF250
PS - 1970 F250 with a 360
Old Jun 30, 2010 | 04:14 PM
CougarJohn's Avatar
CougarJohn
Norm, it sounds like the distributor is bad. The vacuum pulls on a diaphram which pulls the plate against springs to alter the timing. Something is going wrong in the geometry in your distributor. Possibly the little plastic bearings are shot.
I would get a rebuilt distributor and a new diaphram.
Semper Fi
Old Jul 1, 2010 | 12:00 AM
xstrange's Avatar
xstrange
Yeah, that sounds like a blown diaphragm in the vacuum advance. As soon as you get above idle, and the carb port tries to apply vacuum to the advance unit, it just sucks in air through the hole in the diaphragm. It's not just a vacuum leak, which will make it run lean overall, but the incoming air will be coming in through that port right in the throttle bore, which is going to mess with the air flow around the throttle plate area, disrupting the carb's ability to atomize the fuel. And, I believe the vacuum advance port is only in one of the two primary barrels, so one barrel would be working okay, while the other would be burping and coughing.
You probably only need a new vacuum advance unit, not a whole distributor. But while you're working on it, it wouldn't hurt to check out the mechanical advance mechanism to make sure it's lubed and free moving. Check out the shaft bushings too. If it's all worn out, then a whole rebuilt distributor may be the simplest and cheapest repair.
bobbydee
1997 - 2003 F150
Oct 21, 2016 02:39 PM
Zazoos
Oct 7, 2016 09:21 AM
ULpilot
Jul 13, 2015 10:48 AM
Quantum77
Dec 30, 2010 01:57 PM
Jacob1600
Apr 25, 2007 08:20 PM
