Idle problems
Old Apr 24, 2007 | 01:15 PM
Jacob1600's Avatar
Jacob1600
Unhappy Idle problems
Does anyone know what's wrong with a 2001 sport trac that idles rough and dies only when it's warm? Higher rpm runs ok. 99000 miles 4.0L sohc. Just replaced egr valve for check eng light. Checked and inspected IAC valve-good volts to, resistance at, is clean and seems to work fine. MAF sensor seems clean. If it's a vacuum leak somewhere, how do you check for it? If it's intake manifold gasket, is it easy to replace? Thanks for any help. Jacob1600
Old Apr 25, 2007 | 07:53 PM
ReAX's Avatar
ReAX
Vacume leaks are easy to check for, get a can of WD40 or Starting fluid. With the motor running, spray around hoses and gaskets, if the motor revs up you have found your leak.
Old Apr 25, 2007 | 08:20 PM
redwing76's Avatar
redwing76
http://www.2carpros.com/makes/ford/explorer1.htm
Jacob Gervais
Jul 11, 2016 02:47 PM
Jacob Willhoite
Aug 13, 2015 09:40 AM
jacob_powerhouse
29
Aug 11, 2010 09:27 PM
mtbiker
'80-'86 FAQs (Frequently Asked Questions)
28
Jul 21, 2008 09:08 AM
mike a
Jun 30, 2008 09:55 PM
