2001 5R55E Transmission Problems
Old Jun 29, 2010 | 04:46 PM
Bluedog75's Avatar
Bluedog75
I have a 2001 Ranger 4x4 with the 5R55E trans.
<O:p></O:p>
About 3 or 4 days ago, I went to pass another car, when the trans down shifted it acted like it missed the passing gear, after letting off the gas the trans shifted fine but the overdrive light started flashing and shifting hard between 1st and 2nd. The next day everything was fine, no problems (so I thought)<O:p></O:p>
<O:p></O:p>
Now yesterday while driving home from working cruising down the interstate the trans stopped working. Engine revved but no response from trans. Pulled off the side of the road and found out that I had 1st gear only (no reverse either). Limped truck home and found that when going from a stop it seemed like the torque converter was acting up (excessive rpm to get gear to engage).<O:p></O:p>
<O:p></O:p>
After reading some threads on this sight I checked out the link to the valve body replacement. Found on the technical Information thread.
<O:p></O:p>
Dropped trans pan and found that the valve body gasket was blown at the reverse servo area. found another area that was blown out as well. So I know I need to repair the valve body gasket. <O:p></O:p>
<O:p></O:p>
The question is could this be the only problem with it or should I look further into it before getting the parts to replace valve body cover. <O:p></O:p>
<O:p></O:p>
Next question. How do figure out what TSB applies to the valve body and apply it while replacing cover.<O:p></O:p>
<O:p></O:p>
Thanks.<O:p></O:p>
Shawn
Old Jun 30, 2010 | 08:50 PM
g_k50's Avatar
g_k50
Get replacement parts and sound advice from Ford dealer nearest.
Old Jul 1, 2010 | 01:13 AM
mfp4073's Avatar
mfp4073
Could be. Make sure to clean out the valve body real good for any gasket that "got away". Also to make life easier in the future, install a drain plug in the pan.
Old Jul 1, 2010 | 05:28 PM
Bluedog75's Avatar
Bluedog75
Hey Thanks.
I've talked to the local ford dealer yesterday and got the needed parts today. Good Idea about the drain plug, Thanks I wouldn't have even thought to do that before now. I will look into it for sure.
Thanks
Old Jul 1, 2010 | 11:17 PM
mfp4073's Avatar
mfp4073
You can get them in the "help" section of autozone and discount auto or whatever. You will need a half inch drillbit if I remember. They part is only like $5 for the plug.
Old Jul 18, 2010 | 05:19 PM
hvacguy's Avatar
hvacguy
I just did the valve body in my 03 Edge. I installed the Trans Go shift kit and on their advice replaced the EPC solenoid as well. I bought the drain plug from the local parts house and rather than using the nut on the inside I decided to braze it in.
Several thoughts if I had to do it again.
Get the Ford valve body separator plate. It comes with the gaskets already bonded onto it.
Definitely install the shift kit. It shifts much better, but not too harsh.
The EPC solenoid replacement came from the dealer and was replaced as a preventive measure only. The Trans Go folks say it is a common failure item.
Definitely do the drain plug. Taking a bath in tranny fluid is not something I want to repeat.
Flintknapper
17
Feb 18, 2015 08:00 PM
cm6pack
Apr 25, 2013 08:44 PM
cm6pack
Apr 24, 2013 10:42 AM
Bones Digger
20
Jul 9, 2012 01:53 PM
jpj64
25
May 24, 2010 08:58 PM
