1996 f150 codes
Old Jun 27, 2010 | 12:39 PM
jb65542's Avatar
jb65542
1996 f150 codes
hey guys i went to autozone today and used there scanner on my truck and have two codes, im hoping someone can tell me how to fix.
401 egr flow insufficient
300 random/muliple cylinder misfire
my truck is a 1996 302 auto.
Old Jun 27, 2010 | 06:07 PM
ruff08's Avatar
ruff08
I have 401 code also I hope someone can help with issue!! 5.0
Old Jun 27, 2010 | 08:02 PM
danr1's Avatar
danr1
"OBD 2" as in "P0401" Exhaust Gas Recirculation Flow Insufficient Detected
Must be...
Check the rubber hoses between the DPFE and the EGR tube, make sure no leaks and no blockage and......well here this is easier, EGR Valve Problems? A Complete Guide On Diagnosing Automotive EGR Systems
Oh one thing to look for, might be an isolated incident?, wife's Explorer (used what looks like the same DPFE sensor) I found it had yellowish goo oozing from one of the hose nipples when investigating the same problem with it. It caused a blockage at that nipple and was a clear sign of a dead DPFE sensor!
Old Jun 28, 2010 | 12:10 AM
ruff08's Avatar
ruff08
Thanks
Will be cking into that!! Just found out from wife da steering wheel seems loose and not as smooth on turns so may have to look in to that first.
dougal3434
Sep 22, 2016 01:10 PM
Motorhead-42
80
Jul 27, 2016 02:30 PM
1996stroker
29
Jul 8, 2012 06:30 PM
cadillacmob
13
Dec 22, 2010 09:11 PM
SmokeBlower
Dec 14, 2008 04:56 PM
