400 hard starting
Old Feb 7, 2003 | 09:26 PM
biggreen4x4's Avatar
biggreen4x4
400 hard starting
When starting the 400 in my 1978 F-150 the starter seems to drag which makes it really hard to start. Once started you can hear air coming back up the intake and fluttering through the choke plate. Is this an intake valve and how could it be fixed since it has a non-adjustable valve train. Also the oil pressure gauge isn't reading. It's a Sunpro gauge and was reading at about 40 psi before it went to the shop. I believe there could be water in the oil. How would it get into the crankcase. Its at the shop now for transmission work and i'd like them to be able to test drive it without getting stranded down the road.
Old Feb 10, 2003 | 01:59 AM
Superdave's Avatar
Superdave
400 hard starting
Does the air your hearing coming from the carburetor have any kind of an exhaust sound to it? If so, the EGR plate under the carb, could be burnt through.
They were still using some aluminum EGR plates in this time frame, and they were prone to burning out, which will give an exhaust sound coming from the carb while the vehicle is running.
Old Feb 10, 2003 | 03:27 PM
biggreen4x4
400 hard starting
i haven't thought of that yet but i will check it out when i get my truck back. it seems to be letting alot of air back up through the carb.
vtpkrat2
1997 - 2003 F150
May 27, 2016 09:46 PM
IronHorseDriver
1983 - 2012 Ranger & B-Series
Oct 2, 2015 12:01 AM
nathan66669
Aug 24, 2015 01:03 PM
rbtom
Jun 6, 2015 08:01 AM
JBronco
1978 - 1996 Big Bronco
Oct 10, 2002 01:59 PM
