300 6 oil pressure
300 6 oil pressure
Interesting problem. I rebuilt a 300 6 for a truck project. Before I started the engine I ran the oil pump until there was oil to the top of the head. When I started it I couldn't get any oil pressure. Zero on the gauge. So I shut it down and installed a different gauge, same trouble. I'm using the pressure port on the drivers side between the distributor and the bell housing. When I removed the first gauge, there was fresh engine oil in it, like there is oil there. I've pulled the distributor twice to make sure it's engaged in the oil pump, if it wasn't I'm sure it wouldn't go down to seat properly. I also didn't get a pressure reading when I ran the pump with my drill, but I could feel the drill working harder when it started pumping oil. These are pretty good stem gauges from my shop, 0-500 psi in 10lb increments. Should I just try gauge #3? Or could it just be the style of gauges I'm using?
Kuskoal
05-15-2009 04:00 AM
Quick444
13
04-12-2009 04:44 PM
