FICM TEST RESULTS
Old Jun 26, 2010 | 03:03 PM
3KB's Avatar
3KB
FICM TEST RESULTS
Having had a week of rough idle at start and some loss of power, I got on here and did some research. Looks like I have an FICM issue. I just want to make sure I am understanding the readings correctly.
Key on, cycling through glow plugs and buzz ~19.5 volts
After cycle awaiting start 48v
Cranking 47 v
After Crank at idle 19.5 v
Based on the procedures and results in the the Tech Folder, am I interpreting this as a low voltage FICM? I am a week out from a 2800 mile road trip towing. Help..
Thanks
Tim
Old Jun 26, 2010 | 03:05 PM
m-chan68's Avatar
m-chan68
Cranking 47 v
Thanks
Tim
If the voltage reading highlighted in bold red, is what you're getting for FICM_M, then yes your FICM needs to be replaced.
Old Jun 26, 2010 | 03:25 PM
3KB's Avatar
3KB
Yes. 19.5 v at idle.
*****!! That sucks.
Can they be repaired or is it a replace and pay?
Old Jun 26, 2010 | 03:54 PM
cheezit's Avatar
cheezit
there is a thread on how to resolder them. if it works then great. if not its still broken.
Old Jun 26, 2010 | 06:16 PM
npccpartsman's Avatar
npccpartsman
You don't have anything to loose by trying the repair procedure here: https://www.ford-trucks.com/forums/9...procedure.html
Old Jun 26, 2010 | 06:38 PM
m-chan68's Avatar
m-chan68
Sorry to hijack this thread, but this question is directed more toward techs, and truck owners who have replaced their FICMs. Has anyone ever experienced a repeat FICM failure? Just curious.
Old Jun 26, 2010 | 07:15 PM
cheezit's Avatar
cheezit
yes i have had a few drop more then one all have been ems units.
Old Jun 28, 2010 | 05:17 AM
floridahonky's Avatar
floridahonky
I had a second FICM go out on my truck last month, at this point everything was out of warranty.
I was seeing around 30 volts at idle. Symptoms were very rough idle and missing.
I sucessfully follwed the FICM repair procedure and now see roughly 48 volts across the board. (koeo, cranking and idle)
Good luck.
Old Jun 28, 2010 | 04:10 PM
3KB's Avatar
3KB
UPDATE: FICM
Well after a day of being mad about it, I called Swamp this morning and ordered a FICM with the performance flash. Also I got ordered new tunes from Eric at Innovative.
This is starting to get expensive, I am thinking of painting a slot on the side of the fender that says "Deposit Paycheck Here"
Pikachu
Oct 18, 2016 07:06 AM
bjk1159
Sep 8, 2015 05:51 PM
sixamskier
Aug 15, 2015 05:55 PM
CgTopple
Apr 3, 2015 10:58 PM
softpickle
Feb 14, 2015 11:58 PM
