slide lock conversion
Old Jun 26, 2010 | 02:17 PM
tony80's Avatar
tony80
4wd Low
hello i'm new here. I just got a 1980 F100. I would like to change over to regular style door locks. What is all required to make the swap ? Thanks , Tony
Old Jun 26, 2010 | 02:54 PM
Rogue_Wulff's Avatar
Rogue_Wulff
82-86 door latches, complete with lock rods, and either the door panels or drilling holes in your current door panels.
Old Jun 26, 2010 | 02:57 PM
tony80's Avatar
tony80
4wd Low
Thank you. Would lock from a 87-91 work as well?I know where a few of them ready to be crushed are.
Old Jun 26, 2010 | 03:03 PM
Rogue_Wulff
Sorry, i can't answer that. It's possible they are a direct fit, but I can't say for sure.
Old Jun 26, 2010 | 05:06 PM
Fordzilla80's Avatar
Fordzilla80
I think the 8th gens use a cable for the door pull.I'm not sure if they attach to the mechanisms the same way.I think your best bet would be to just get some mechanisms from a late 81-86.
FYI,keep track of which hole each metal rod inserts into,there is one or two that don't get used on the mechanisms(depending on power/non-power).To get the mechanisms out you will also have to unbolt the window track by the mechanisms.
Other than that,Rogue has it covered.You will have to drill the hole in the door too.
Old Jun 26, 2010 | 05:23 PM
tony80's Avatar
tony80
4wd Low
ok thanks everyone
Tony Panchot
Dec 29, 2016 04:52 PM
Tony Tobar
Sep 28, 2016 09:50 PM
tjbeggs
26
May 5, 2011 10:30 PM
ChiefsFan
Kansas Chapter
13
Jun 22, 2004 07:00 PM
Tony
Nov 30, 2001 09:07 AM
