Sponsored by: Real Truck
Tranny spewing fluid
Old Jun 26, 2010 | 11:08 AM
Cowboy99's Avatar
Cowboy99
99 F250 tranny spews fluid when 4x4 in deep sand. ok otherwise.
not sure if tranny going bad or cooler blocked. any one with same experience? how to diagnose?
surprised when fluid spews on exhaust and catches fire. happened several times.
Old Jun 26, 2010 | 05:07 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The '99s don't have enough transmission cooling. They didn't have a transmission cooler in the radiator. If you changed the radiator for one with a transmission cooler and changed the air to oil cooler to a 6.0L cooler you probably would fix the problem.
Old Jun 26, 2010 | 07:05 PM
Cowboy99's Avatar
Cowboy99
interesting. i'll have to check it out.
Old Jul 9, 2010 | 09:05 PM
bushinspector's Avatar
bushinspector
We have a 03 and had the same problem. where does the fluid come from?
Old Jul 11, 2010 | 09:45 PM
Cowboy99's Avatar
Cowboy99
i never found the specific place, but i'm pretty sure it's some kind of relief valve.
just not sure why it relieves on the exhaust which catches fire.
i think i'm going to make the suggested changes. did a little research so i think i know what to replace. just want to make sure i don't have any blocks.
Old Jul 12, 2010 | 06:32 AM
Mark Kovalsky
There is no relief valve on the transmission.
Old Jul 12, 2010 | 02:00 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Previous 250 I had it came out the filler tube.......
Old Jul 12, 2010 | 06:01 PM
Cowboy99's Avatar
Cowboy99
so is the only place to leak out the filler tube? cause i never could locate where it leaked. only that it always spews on the exhaust and catches fire. only leaks with 4x4 in heavy sand. had truck in sand often well over 100K miles with never a problem before. never happens regular driving or towing.
Old Jul 13, 2010 | 06:36 AM
Mark Kovalsky
There is a vent on top of the trans. If you get fluid coming out of here the trans was overfilled.
Old Jul 13, 2010 | 02:15 PM
bushinspector
Can it overheat and then come out and not be over filled?
Old Jul 13, 2010 | 02:26 PM
TennesseeMustangPerf's Avatar
Is your 2003 a 7.3L or 6.0L?
Old Jul 13, 2010 | 04:04 PM
Mark Kovalsky
I've tested transmissions above 300°F and never had one eject fluid from the vent unless it was overfilled.
Old Jul 13, 2010 | 09:43 PM
bushinspector
Its a 2003 F250 XLT Super duty Triton 5.4 L engine
