Source for metric fasteners?
Old Jun 25, 2010 | 09:15 PM
Ford_Six's Avatar
Ford_Six
My latest project is hitting a little snag- Mercedes, in their infinite wisdom, used 12point M10x1.0 bolts to hold the flywheel to the crankshaft on their diesels. It's a 12mm head, so of course I didn't have a high quality 12point 12mm socket and wound up rounding several of these bolts. Now, I need to replace these and can't find anything that will work and not cost a fortune. All the M10x1.0 bolts I can find are a 17mm head, which is pushing it for fitting in the space, socket heads seem unavailable in that size, and Mercedes wants $7.80 EACH for these bolts which are necked and possibly a TTY anyways.
I've tried Fastenal, Mcmaster-Carr, and a few hours worth of online searching, but have come up empty. Does anyone have a source for this size thread in a socket head or a 14mm head?
Old Jun 26, 2010 | 06:52 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What's the length?
MMCC has a Distribution Center in nearby Hawthorne where I can buy 'onesies' over the counter. Would grade 12.9 inhex be suitable?
http://www.metricmcc.com/catalog/Ch1/1-43.pdf
Old Jun 26, 2010 | 12:16 PM
Ford_Six's Avatar
Ford_Six
Interesting, they never came up during my search. For the time being, I have ordered some coarse thread 10mm socket head screws, partially threaded in 70mm length, along with a 10x1.0 die. I'll cut them down, and thread them the way I need for this prototype. When I get to production, even just for my own, I'll order the proper ones. Thanks.
Old Jun 26, 2010 | 12:24 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What length do you ultimately need Jared?
Flywheel bolts are stout for a reason. Be real careful modifying something for this application.
Old Jun 26, 2010 | 12:36 PM
Lazy K's Avatar
Lazy K
Disregard.
Old Jun 26, 2010 | 01:48 PM
just another truck's Avatar
just another truck
if they dont have them, they will get them..
Page 1 of 1 Results: 1 - 10 of 10
Location Address
Store Code: IDREX
Rexburg, ID 83440 262 Dividend Dr
Rexburg, ID 83440
P: (208)656-0185
F: (208)656-0016 Make IDREX your local store. Why Should I Set a Local Store?
By setting a local store, you are able to see if the product is available at the store without using the Store Availability search feature.
Store Code: IDIDA
Idaho Falls, ID 83402 115 E Anderson
P: (208)542-6008
F: (208)542-6010 Make IDIDA your local store. Why Should I Set a Local Store?
Store Code: IDPOC
Pocatello, ID 83201 2610 Suite B Garrett
Pocatello, ID 83201
P: (208)478-6810
F: (208)478-6811 Make IDPOC your local store. Why Should I Set a Local Store?
Store Code: MTBOZ
Bozeman, MT 59718 8235 Huffine Lane
Bozeman, MT 59718
P: (406)582-8119
F: (406)582-8142 Make MTBOZ your local store. Why Should I Set a Local Store?
Store Code: IDBUR
Burley, ID 83318 536 Overland
Burley, ID 83318
P: (208)677-4605
F: (208)677-4617 Make IDBUR your local store. Why Should I Set a Local Store?
Store Code: UTLOG
Logan, UT 84321 642 North 1000 West Su.#109
Logan, UT 84321
P: (435)787-2994
F: (435)787-2995 Make UTLOG your local store. Why Should I Set a Local Store?
Store Code: WYCDY
Cody, WY 82414 321 Robert Street
Cody, WY 82414
P: (307)527-4203
F: (307)527-4205 Make WYCDY your local store. Why Should I Set a Local Store?
Store Code: UTTRE
Tremonton, UT 84337 190 South 200 West Street
Tremonton, UT 84337
P: (435)257-1771
F: (435)257-1773 Make UTTRE your local store. Why Should I Set a Local Store?
Store Code: MTBU1
Butte, MT 59701 3928 Wynne Ave #3
Butte, MT 59701
P: 406-494-7755
F: 406-494-3190 Make MTBU1 your local store. Why Should I Set a Local Store?
Store Code: IDJER
Jerome, ID 83338 374 American Ave.
Jerome, ID 83338
P: (208)324-0140
F: (208)324-0142 Make IDJER your local store. Why Should I Set a Local Store?
Old Jun 26, 2010 | 05:03 PM
Ford_Six's Avatar
Ford_Six
I need them to be 30mm long. The ones I am modifying will not be actually used in an operating engine, they are for setup so I can take a bunch of pics and have everything look right plus have the flywheel bolted up tight so I can square the input shaft to make sure it's all correctly aligned.
Fastenal does not have these on the shelf. I checked the Rexburg store, and Idaho Falls plus a few other places. Fastenal does have the hex head ones listed online, but they are a 17mm head which places the bolts a bit too close to get a socket on them.
Here's what they put in the car from the factory:
These appear to be a TTY, but I have not been able to get a straight answer on that aside from the FSM says not to reuse them. Pre-78, they used socket head bolts.
There are 12bolts holding the flywheel on, so strength shouldn't be an issue with 10.9 grade bolts.
Old Jun 27, 2010 | 05:19 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Definitely look TTY.
Seen many similar bolts in German connecting rods.
Old Jun 27, 2010 | 09:01 AM
dchamberlain's Avatar
dchamberlain
Can you get them from Worldpac? Who, guessing by the copyright on the photo, is the company that makes them?
Old Jun 27, 2010 | 12:51 PM
fabmandelux's Avatar
fabmandelux
WORLDPAC - speedDIAL
Old Jun 27, 2010 | 09:04 PM
Ford_Six's Avatar
Ford_Six
I'm using Linux, so no catalog for me. The company I priced them through is called Fastlane, they specialize in these cars, and typically have the best prices. They had the $7.80 price. I suppose I could call the MB dealer in Pocatello and get the real Mercedes price, but I have a feeling it's a hair more expensive. Put a three pointed star on anything and the price goes up-
Doug351
Mar 24, 2016 09:07 PM
JTATMAN
Jul 1, 2010 05:46 AM
tomrooster-1
Jan 7, 2006 03:48 PM
seadoo
Jul 5, 2005 06:07 PM
