Banjo Nut installing?
Old Jun 25, 2010 | 04:17 PM
Mike Bartlett's Avatar
Mike Bartlett
So I pulled the Banjo nut (under the turbo) to replace the two shims in hopes of resolving a fuel leak. Now I can't get the nut started/threads to grab. I can barely get my fingers under the turbo base to align the nut and thread it at the same time is near impossible. I have been trying for about 3 hrs but no luck. Any ideas or suggestions? It looks like the turbo has to be pulled but not sure how to do that? I would obviously prefer not to pull the turbo but is that the only way? Grrr!
1995 7.3PSD.
Thanks
Mike
Old Jun 25, 2010 | 04:42 PM
DRRXR's Avatar
DRRXR
Wink
1995 7.3PSD.
Thanks
Mike
Maybe this link will help. plowhands notes may be useful in getting it in there.
https://www.ford-trucks.com/forums/4...fuel-leak.html
Old Jun 25, 2010 | 05:17 PM
Talyn's Avatar
Talyn
I believe the threads on that nut are backwards correct?
Old Jun 25, 2010 | 05:26 PM
DRRXR's Avatar
DRRXR
I dont think so; only the fuel bowl stand pipe has lefty threads.
The turbo makes it hard to align and press down a turn it at the same time.
Old Jun 25, 2010 | 05:29 PM
FARM69's Avatar
FARM69
First.. take a break. Your hands will work a lot better after you've relaxed a little.
Although I have a different turbo pedistal, you should be able to your hands in there without any problems. My fingers are pretty short and stubby and I little problems getting the bolt started. Make sure the part that has the fuel lines connected to it is matched up. If it's not... it won't thread in there. Hope that helps.
Old Jun 25, 2010 | 05:53 PM
Mike Bartlett
Guys, thanks for the link, I just read through it, and the advice. I am burned out for today so I'll try again in the morning using some tips posted here. I can somewhat get my fingers under the turbo base and can turn the nut but have a hard time getting everything aligned, push in on the nut and turn it all at the same time.
I am leaving next Saturday for a trip to Vegas pulling a trailer. Gotta get this done as well as fix my AC, Flush coolant and replace the trans fluid. I thought this fuel leak would only take a few hrs, doh! I did replace all the fuel pump hoses as well. It appeared the leak was dripping from the banjo bolt when I had it running.
Thanks again,
Mike
Old Jun 25, 2010 | 06:12 PM
DRRXR's Avatar
DRRXR
Talking
Thats a excellent idea I think I will do that myself
Thanks again,
Mike
Mike
Farm69 is right a lot of the times it takes setting it to the side and come back later
I think I will even take his advice, right now.
Old Jun 25, 2010 | 06:27 PM
Mike Bartlett
You read my mind. Just showered and ready for some hops, maybe, damn with as frustrated as I am this may be a Matini night, ah what the hell I'll start with a beer and go from there
Thanks guys,
Mike
Old Jun 25, 2010 | 09:22 PM
pjwoolw's Avatar
pjwoolw
Welcome aboard Mike! I'm in San Ramon if you need a third hand or second set of eyes. I also have the AE scanning software if you ever need it scanned.
Old Jun 25, 2010 | 10:07 PM
Mike Bartlett
Hi Pete,
Thanks for the offer I may take you up on that. I am heading over to Livermore Ford in the morning to pickup two new metal washer/gaskets that go on each side of the banjo nut, i tweaked one today, I should get started again arounf 9am or so? I'll let you and everyone else know how I do on getting this bugger on. My wife is worried now since I commited to driving our truck and pulling this trailer, not mine, down to Vegas next Saturday.
Thanks...
Mike
Old Jun 26, 2010 | 12:24 AM
Mike Bartlett
BTW...If/when I get this back together do I need to bleed the air out of the fuel system? I have obviously replaced the fuel pump hoses/etc so will she start right up or???
Thanks
Mike
Old Jun 26, 2010 | 12:35 AM
pjwoolw's Avatar
pjwoolw
Fill the bowl about half way with some Redline diesel fuel conditioner (Napa on Stanley) before you install the filter. That will get you started. There isn't really any way (that I'm aware of) to purge the air prior to starting. It will take a little time for all the air to purge. A good run or two on the freeway should do it. Did you get my e mail?
Old Jun 26, 2010 | 12:35 PM
Mike Bartlett
Well I just can't seem to get this banjo nut started/installed into the rear of the pump. The hard fuel lines that the banjo nut goes through seems to be bent a bit downward which causes the bolt to go into the rear of the pump crooked. I just can't get anything in that small space to tweak that hard line upward and at the same time thread the bolt into place.
Guess its time to tow it to the dealer
Mike
Old Jun 26, 2010 | 12:46 PM
Cuda_jim's Avatar
Cuda_jim
Mike
Loosen up the small lines where they connect to the head, this might give you enough wiggle room to get the banjo bolt started. My 2 cents
Old Jun 26, 2010 | 12:49 PM
Mike Bartlett
I thought about that briefly but those are about as hidden as the banjo bolt under the turbo. I'll look again and see if I can get to them? My thought was I would loosen those then never get them back on like this damn banjo nut. I guess I'm getting gun shy?
Mike
