'78 Supercab side window falling out
Old Jun 25, 2010 | 12:24 PM
1FastGambler's Avatar
1FastGambler
The top hinge for the drivers side supercab window is no longer attatched to the cab.
What's the best way to fix this?
Old Jun 25, 2010 | 12:45 PM
fair67driver's Avatar
fair67driver
I am new to supercabs.....mine does not move.
Old Jun 26, 2010 | 09:50 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Fixed rear side windows were standard, flip-out opening windows were an option.
Old Nov 8, 2010 | 09:55 AM
1FastGambler
Anyone know the best fix for this?
Old Nov 8, 2010 | 10:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Which type of glass do you have...fixed or flip out?
The parts do not interchange.
Old Nov 8, 2010 | 10:10 AM
duste's Avatar
duste
The plastic hinge is worn or broken, it's a pain in the *** the do the first time as there is a nack to it. There is a cover over the screw holding the rear hinge to the cab, remove the cover and the screw. With the window open about 4 inches,(more than it will normally which is why you remove the screw) using a small pair of needle nose pliers, pinch the black plastic pieces together and gently pull back of the window and hopefully the hinge will let go. The little black plastic pieces are what's broken, I seen a link on here somewhere where you can buy them but they are $24/hinge if I remember right.Once you do the first one this post will make more sense. Best of luck.
Old Nov 9, 2010 | 05:28 PM
1FastGambler
The windows are tip out.
Thanks for your help!
Old Nov 9, 2010 | 08:49 PM
steponit's Avatar
steponit
Old Nov 10, 2010 | 05:44 AM
NumberDummy
Originally Posted by steponit
D5FZ73302A12A (replaced D2FZ73302A12A & D3FZ73302A12A) .. Quarter Window Hinge Retainer / Obsolete
Fits: 1975/79 F100/350 Super Cab & 1972/80 Pinto/Bobcat Station Wagon.
No Ford Dealer or obsolete parts vendor has D3FZ73302A12A or D5FZ73302A12A.
D2FZ73302A12A =
FRED GRANDE FORD in Richmond MI has ONE = 586-727-3415.
HEMINGWAY MOTORS in Andrews SC has TWO = 843-264-5243.
No one else has any.
Old Nov 19, 2010 | 12:52 PM
agexperts's Avatar
agexperts
LMC truck sells them, check their website
Supercab
1983 - 2012 Ranger & B-Series
Jun 21, 2014 07:27 AM
hayj
WTB - Parts & other
Jun 7, 2014 05:24 PM
HeeHaw78
Jul 22, 2011 12:14 PM
timcos
Appearance & Dress-Up
Jul 15, 2008 06:56 PM
