Tach reads high.
Old Jun 24, 2010 | 09:14 PM
LP2V's Avatar
LP2V
Tach reads high.
Looking for help with tach that reads high.
Start idle is 1K on tach, with dial back timing light reading 860rpm. serial port connected to efi ecm, readout is same as timing light. Efi ecm is Haltech and harness. Dist. is a coil in cap GM type. it seems the higher the rpm, the greater the spread becomes. Had second tach tested at local instrument shop and it tested correct.
I'm using the same tach connection that was on the origional tac lead before conversion. it seemed correct.
Any ideas will be greatly appreciated.
Thanks in advance.
LP2V
'95 roller 302 +.020
Dart heads
hooker ceramic long tube
Edelbrock performer
Comp 260er
Haltech ecm
1000cfm throttle body
eagle/srp
aod
Old Jun 24, 2010 | 10:49 PM
Rogue_Wulff's Avatar
Rogue_Wulff
It sounds like the 4/6/8 switch in the tach is set to 6 cyl mode. I'm assuming it's an aftermarket tach, considering the list of goodies.....
Old Jun 24, 2010 | 10:58 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
I was about to make an idiot reply, but the math works out to what you are saying Rogue.
Old Jun 25, 2010 | 08:28 PM
TheKirbyMan's Avatar
TheKirbyMan
I have a similar problem, my factory tach reads about 150rpm lower than my Sunpro tach did when I had it hooked up. I read somewhere on here about how there was a magazine article in like the 80s or 90s where they did a test, and found that various different brands of tachs all read differently, with the only truly accurate one being the computer-based one.
Perhaps you could try a different tach (maybe borrow one from a friend who has one?) and see if you get the same reading.
Old Jul 5, 2010 | 04:26 PM
LP2V's Avatar
LP2V
Thanks for the reply,
I haven't tried a stand alone tach. That's next on the list of things to try. I'll post the results.
LP2V
Nero Morg
Jul 31, 2012 10:44 PM
Kijutsu
1983 - 2012 Ranger & B-Series
Aug 22, 2008 01:46 PM
MintFord
Jan 19, 2007 04:05 PM
MagBayBrian
Electrical Systems/Wiring
Nov 25, 2002 05:32 PM
bcrate
1997 - 2003 F150
Nov 6, 2000 06:47 PM
