Oh, I get it now - no, the weight itself is not advantageous, it's just a byproduct of the strength the bumper is built in mind with. Of course there are plenty of strong and light bumpers out there such as those made by Ali Arc, but those of us with limited financial resources but with access to welding equipment and reasonably-priced steel just kinda learn to live with the extra weight. It's a pick your poison type of situation, you really want cheap light and strong all at once but only have two of those properties can actually coexist (ebay deals and CL finds excluded).
heavy bumpers do suck, just ask my front end. but my bumper comes in at over 400 lbs. Two grown men can barely pick it up, but it is an oilfield special made of drill stem, 1'' plate, and heavy wall 1'' pipe.
400 lbs is a LOT of extra weight for the front end to handle. We have a guy here locally that builds custom bumpers, when I talked to him about building me one he said it would come in around 150 lbs. You can have lot's of strength by proper fabrication and not have to use such heavy steel.
Holy overkill man, why in the world would you possibly need 1"-thick plating and pipe wall thickness? How do you weld this, I can only imagine the amount of current needed to make for good penetration with a material that can dissipate heat so good... Actually scratch that, how do you even drill this for mounting bolts and such, lol
Actually 400 lbs ain't much at all, when you load a 1-ton truck to its capacity I bet there's at least that much weight transferred to the front. Of course if you're gonna run this weight there all the time you'll probably want the strongest wear items you can find (ball joints, tie-rods, bushings, etc.) and even so they will likely wear out faster than if you just run around empty. I do agree with what your bumper builder told you tho.
Originally Posted by Festus Hagen
Strength is a totally different story, not weight, heavy metal doesn't mean strong.
Oh, but of course, all I was saying is that if you're working with steel you can't entirely do away with excess weight if you're going for strength. There is acceptable excess weight, and then there is just plain too much, considering the plow mount duties for the OP's bumper I'd call that still acceptable...
I just have to say if it was me drilling 1" plate I wouldn't drill at all lol
Nothing like 60,000 PSI of water mixed with 80 grit sand being shoved through a .022 orifice to slice 1" steel like it's butter.... gotta love waterjet technology
All the steel I used was free or traded for parts as well as the paint job. I used what I could get. The 1/4x8x8 tube wasn't to heavy by it's self but the 1/2x4x6 angle for the plow mount and the 3/8 plate for the tube supports did add some wieght. I think the truck will handle it ok as it only dropped the front about a 1/2". Funny part is I still have to do the rear one and it is also gonna be made of the same type tube. But it will be used for extra storage with sealed locking doors. The plow I have for it is a Northman 7 1/2' blade. It wieghs in at about 700#s so I wanted something stout to carry it.
No it doesn't. But when you are limited by budget and availability of materials size helps. I know that some of the best aftermarket bumpers out there are made by Buckstop and they are not light wieght. But one of the owners of the company I work for had one on his 05 powerstroke and it was able to survive 15 deer impacts without anything but new paint. He just bought a 2010 stroke and couldn't get a Buckstop for it. He bought a different bumper that was lighter and "reenforced". It didn't survive the first deer hit. He has talked about haveing me build a bumper for his truck. So in the end you build it for what you need. I would prefer it to be lighter but when you may hit things at highway speeds you don't want to have to rebuild it again.
exactly my line of thinking. Thats why mine is called the treekiller.
