Sponsored by: Real Truck
swapping d50 t0 d60
Old Jun 24, 2010 | 05:16 PM
mrblonde108's Avatar
mrblonde108
swapping d50 t0 d60
I have a 99 f250 truck, with manual hubs and transfer case. I just aquired a 2002 d60 front differential that came off a truck with esof and auto/ manual hubs.
I'm hoping i can swap the hubs off my 99 d50 02 and put them on the 02 d60. because i just rebuilt it with new wheel bearings and all.
thanks
Old Jun 24, 2010 | 05:54 PM
mwsF250's Avatar
mwsF250
Unfortunately, I don't know the answer to the question...
But I am curious why you need to change? Did you actually manage to break a D50? I gotta know how?
Old Jun 24, 2010 | 06:44 PM
mrblonde108
no lol didn't break it. i'm going to convert to dually in the future and figured i'd rather have the d60 in there. i heard good things about the d60.
Old Jun 24, 2010 | 10:54 PM
rob29956's Avatar
rob29956
I think the differences in the hubs will be flange thicknes and wheel stud threads. Early had coarse threads and late had fine threads locking hubs will swap as well as steering knuckles and outer axle shafts. The diff cover will even swap. Abs may be an issue with swapping your axle so double check it to see what you need. also make sure the mounting pads are corect for the springs.
Hope that helps,
Rob
Old Jun 25, 2010 | 12:01 AM
redford's Avatar
redford
FTE Leadership Emeritus
He may have only rear ABS.
Old Jun 25, 2010 | 12:19 AM
rob29956's Avatar
rob29956
Rear Abs will make it a much easier swap
Old Jun 25, 2010 | 07:52 AM
mrblonde108
how do i know if i have front ABS?? my truck doesn't but the donor d60 has a wire going to the hub. Don't know if it's for abs or for the electic hubs. there is also a hose on the brake bleeder that goes to the engine compartment. what's that all about?
even if it does have ABS can't i swap the the whole spindle??? wheelbearing and all??? i don't think the axle has a sensor in it?/???
Old Jun 25, 2010 | 08:19 AM
krewat's Avatar
krewat
The hubs are VACUUM not electric. If your truck does NOT have the ABS sensors, it's not front-ABS. If the new front-end DOES have them, just cut the wires and leave the sensor in the hole as a plug and plug the vacuum port on the knuckle.
The locking hubs should be the same, but depending on what part of '99 your truck is, the wheel bearings might be different. The entire knuckle should bolt on as-is though. I think.
Zach Hill
32
Dec 9, 2014 12:51 PM
mudslinging79
1978 - 1996 Big Bronco
May 6, 2014 09:33 PM
hasteranger
Nov 4, 2013 08:40 PM
Molineguy
Feb 2, 2011 01:46 PM
