Transmission what is too hot
I have an E450 30' Class C motorhome and tow a vehicle. Combined weight is around 17,700. This is an 06 chassis with the 5R110 tranny. Using a scangauge since last fall. This is the first time I have been in warmer weather since getting the gauge. In the last few weeks have been towing in warmer ambient temps like 90's and 80's and have seen higher tranny temps. Prior to this warm weather I was generally in the 160's. Just the other day climbing a pass to 8,400 feet it got to 209. How hot is too hot for the good of the tranny? Jim
209 is warm but not bad as I belive that the leaving the trans temp not the sump temp.
My trany guy say you realy want to know the sump temp cause if the sump / pan is over 190 your not going to pull enough heat out of the trans.
This was on my 96 f150 i was pulling a 8000lbs load most of the time my sump was 140 once i pulled 4 ton of stove pellets in the Enclosed trailer so i'm sure it was over 12000 in a f150 pan temp got to 185. This was with Royal purples Max ATF.
What ATF are you using?
Most of the good synthetic ATFs are rated for higher temperatures than some of the internals of your transmission. Where the temperature is taken is really important and I need to look at my tranny to see where the sending unit is.
On our Trophy truck (extreme example) we take the temperature on the output line and the pan. We had a situation where the pan temperature was fine but it was because of a restriction in the cooler so the fluid stayed in there longer and was cooled. Temps in the output line were skyrocketing and the converter cooked to the point it destroyed (burnt to pieces) a Wix racing filter that was inline, it literally was in pieces when I cut the filter open.
My point is it is important to know where in the system you're looking at the temps and I really wished the factories would give us the highest temperature rather than the pan temperature.
Thanks to everyone for the feedback. If I were to do something about the cooler what type of business would I go to for that?
Jim
Hi Jim... er, sorry... Mark,
209 is warm, but not too hot. You are going to see slight variances depending on where your gauge sending unit is installed. ALso, being a van it is probably going to run a little hotter than a truck anyway. At 209 though, you are okay. Did you top off the oil yet? I am sure that it will go down some when you stick in the full ammount of fluid.
ksgriffin150
1997 - 2003 F150
05-16-2016 09:41 AM
180, 2000, 60, f250, f350, ford, heats, hot, temp, temperature, too, towing, tranny, transmissikon, transmission
