dash instrument lights dont work
Old Jun 24, 2010 | 10:14 AM
john-rambo's Avatar
john-rambo
hey guys
i just got myself an 82 f100 (aus)
its a great car, but the dash instrument lights dont come on with the headlights.
i'm hoping this is just a fuse problem, but none seem to be busted.
could someone please post a fuse diagram so that i can make sure everything is where it should be.
cheers!
Old Jun 24, 2010 | 10:26 AM
Franklin2's Avatar
Franklin2
If the fuse for the instrument lights is good, turn the headlights on and check for voltage on both sides of the fuse. Turn the headlight switch back and forth and keep checking it. If you get no voltage, and your running lights are working, then you have a problem with the headlight switch.
Old Jun 24, 2010 | 10:46 AM
john-rambo's Avatar
john-rambo
thanks for the rapid reply!
it looks like my headlight switch is the problem.
is there anything i can do to fix it? or should i be looking for a replacement?
Old Jun 24, 2010 | 10:52 AM
Franklin2's Avatar
Franklin2
Usually it's the dimmer control on front of the switch that goes bad. If you do not need the dimmer function, you could jump the brown wire(running lights wire) over to the blue/red wire(feed to the instrument light fuse wire). Inside the switch they tap into the brown wire and run it over to the front of the switch to the rheostat, and then out on the blue/red to the instrument fuse. Then from the fuse to the lights themselves.
Old Jun 24, 2010 | 10:53 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Replacement is usually the best option. The switch has a variable resistor in it for the dashlight dimmer, and the wound wire gets wore out pretty easily.
Old Jun 24, 2010 | 10:55 AM
john-rambo's Avatar
john-rambo
thanks for your help mate!
i will give it a shot
Old Jun 24, 2010 | 11:11 AM
smashclash's Avatar
smashclash
can you get one of these at a traditional auto parts store or does this require a trip to the junkyard or dealer?
Old Jun 24, 2010 | 11:17 AM
Rogue_Wulff
Most parts stores carry these, but some have real crappy quality.
erik68
Apr 13, 2014 09:36 AM
FordFinatic157
Oct 5, 2013 09:35 PM
Zpiroshki
Mar 25, 2012 09:44 AM
nickbaize
Jul 17, 2010 03:27 PM
muscletruck7379
18
Oct 30, 2004 05:40 AM
