cowl vent help please
Old Jun 26, 2010 | 12:44 PM
Mervy49's Avatar
Mervy49
Cool cowl vent
Originally Posted by Julies Cool F1
Yours did look different. I wonder if someone "fixed" it, or possibly it was a Canadian Variant that was tooled a bit different.
I know mine is stock for 51 and was NOS when I bought it to install (none there wne I bought the truck). But no doubt the theads on mone and in the parts manual specify #8-32
Mine on the 49 is different from the pic too, it does'nt have the channel under the cover either!
I went and filled and smoothed the cowl vent. I had mean feelings toward the way it performed in stock configuration.....
Old Jun 26, 2010 | 01:56 PM
Julies Cool F1's Avatar
Julies Cool F1
Well this is where the poor quality of Ford documentation yields it's ugly head.
I looked up the Cowel Vent assembly in a different manual and this is what I found.
First, there is only one part number for the cover from 48-52 (7C 8102133-A) which supposedly negates a change between years. Again I think the covers were modified during the production run to incorporate improvements - like being able to install and remove the cover by just loosening the bolts (instead of having to remove them completely) and sliding the cover to the side. Or, different plants (Windsor in Canada for example) may have had a different design using the tooling from auto vents or something - whatever!
But also here's another tweek! This manual shows the four bolts as being #10 - 32 x 3/8!!!!! And I'm sure that those are the correct ones shown in the picture in this manual.
When I measured mine last night they were #8s go figure.
So, kiwi, if you are ordering bolts and nuts, order both #8 -32 x 1/2 and #10 -32s x 3/8 and both 8-32 and 10-32 nuts!
Inconsistant and non standard production and inconsistent and non standard documentation!
Old Jun 26, 2010 | 06:33 PM
kiwi's Avatar
kiwi
Nothings ever as simple as it seems! I think its very possible that the variation is due to New Zealand and Austrialia Ford dealers importing there trucks etc from Canada as we are RH drive over here! Thanks for your help,Julie can i ask one more thing of you please,on your cowl vent what measurement (depth) is the channel at the centre line of the cab (mine is 5/8") and i would hope yours is the same?
PS take a look at my company web site www.hawkesbayengineer.co.nz theres more recent pic's etc of my 56 and other restoraion work i have done for customers Kind regards to all, Kiwi.
Old Jun 26, 2010 | 07:40 PM
dustybumpers's Avatar
dustybumpers
Originally Posted by kiwi
Hey Dustybumpers thanks for the advise,i dont seem to have "manage attachments" as an option in the additional options so still stuck i afraid!!
you should have enough posts to be able to use your options. don't use quick reply,click on post reply, at the end of the text, before quick reply<TABLE class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><THEAD><TR><TD class=tcat>Additional Options </TD></TR></THEAD><TBODY id=collapseobj_newpost_options><TR vAlign=top><TD class=panelsurround align=middle>
<FIELDSET class=fieldset><LEGEND>Miscellaneous Options</LEGEND><LABEL for=cb_signature><INPUT id=cb_signature tabIndex=1 value=1 CHECKED type=checkbox name=signature>Show your signature</LABEL>
<LABEL for=cb_parseurl><INPUT id=cb_parseurl tabIndex=1 value=1 CHECKED type=checkbox name=parseurl>Automatically parse links in text</LABEL>
<LABEL for=qr_retrtitle><INPUT id=qr_retrtitle value=1 CHECKED type=checkbox name=vbseo_retrtitle>Automatically retrieve titles from external links</LABEL> <INPUT value=1 type=hidden name=vbseo_is_retrtitle>
<LABEL for=cb_disablesmilies><INPUT id=cb_disablesmilies tabIndex=1 value=1 type=checkbox name=disablesmilies>Disable smilies in text</LABEL>
</FIELDSET> <FIELDSET class=fieldset><LEGEND>Attach Files</LEGEND>Valid file extensions: gif jpe jpeg jpg pdf png psd
******** type=text/javascript src="http://ui.ibsrv.net/ibsrv/res/src:www.ford-trucks.com/get/forums/clientscript/vbulletin_attachment.js?v=375">*********>******** type=text/javascript> <!-- var newpost_attachmentbit = '\r\n \r\n %5$s\r\n (%6$s)\r\n
'; vB_Attachments = new vB_Attachment('attachlist', ''); document.write('<input type="button" id="manage_attachments_button" class="button" tabindex="1" style="font-weight:normal" value="Manage Attachments" title="Click here to add or edit files attached to this message" onclick="vB_Attachments.open_window(\'newattachmen t.php?t=968404&poststarttime=1277599079&posthash=1 0b91ad49c4ea45debc33c799459f7fb\', 480, 480, \'9044173\')" />'); //--> *********><INPUT style="FONT-WEIGHT: normal" id=manage_attachments_button class=button title="Click here to add or edit files attached to this message" tabIndex=1 onclick="vB_Attachments.open_window('newattachment .php?t=968404&poststarttime=1277599079&posthash=10 b91ad49c4ea45debc33c799459f7fb', 480, 480, '9044173')" value="Manage Attachments" type=button> <NOSCRIPT></NOSCRIPT>
</FIELDSET> <FIELDSET class=fieldset><LEGEND>Thread Subscription</LEGEND><TABLE border=0 cellSpacing=3 cellPadding=0><TBODY><TR><TD>Notification Type:
<SELECT tabIndex=1 name=emailupdate> <OPTION value=9999>Do not subscribe</OPTION> <OPTION selected value=0>No email notification</OPTION> <OPTION value=1>Instant email notification</OPTION> <OPTION value=2>Daily email notification</OPTION> <OPTION value=3>Weekly email notification</OPTION></SELECT></TD></TR></TBODY></TABLE></FIELDSET>
Old Jun 27, 2010 | 01:15 AM
Julies Cool F1
Well it was a little difficult to measure for two reasons. First it's on the truck and hard to get anything in there, but also , if you look back at the picture, you'll notice that the channel top is not flat but rather a little rounded/pulled up in the center.
At the edge of the channel, from the surface of the vent lid down to the outside surface of the channel on the corner was 3/8 inch. In the middle of the channel is 1/2 inch.
Because the cover is slightly convex (taller in the center), I would imagine in the center we would get the extra 1/8 inch to make it 5/8. You can see that curvature in my pic. The top edge of the channel is curved and the bottom - mating surface to the frame - is flat.
Old Jun 27, 2010 | 01:55 AM
kiwi's Avatar
kiwi
Thanks for the post dustybumpers double checked my options and i dont have "attach files" in my menu as shown in your post.
I will get my wife to see if she can sort out what i'm doing wrong!! as she is more pc literate than me.
Regards kiwi.
Moe Craig
Apr 26, 2015 03:14 PM
BradsF1
28
Nov 29, 2014 11:35 PM
John Morton
Oct 27, 2013 12:38 AM
52 5 star
Sep 24, 2012 11:46 AM
Matts68f100
Apr 21, 2003 08:04 PM
