Wheel Offset on My 52
Old Jun 26, 2010 | 08:15 AM
cts1954's Avatar
cts1954
I came across a really nice set of Mclean chrome wire spokes, 15" X 8" that I would like to put on my 52 F1. Problem is they may have alot of offset. They only have a 205-60 tire on them now but I planned on changing them to a larger diameter. I have mocked up one of my front fenders and put a wheel on, the tire is outside of the fender by a small amount at the top but with lots of radial clearance, probably 4-5 inches from the top of the tire to the fender (this will change with a 235-60 tire). Is anyone running wider tires with a similar offset and is it critical that the tire be inside the fender. I think they will look relly nice with a 225 or 235 tire on them and I would still have over 2 inches of clearance.
Thanks
Old Jun 27, 2010 | 01:27 AM
Julies Cool F1's Avatar
Julies Cool F1
I'm not sure about setback on this but I'll bump it back up for you.
Spoke wheels on an F1 - don't think so - too heavy!
Old Jun 27, 2010 | 06:01 AM
norvillebob's Avatar
norvillebob
measure the back spacing and approx rim width, that would help us with your question. backspacing is measured with rim facing down and measure from where rim mounts to hub to the edge of the rim. use a small thin piece of wood ect.. and lay it on the rim edge and measure down.
bob
Old Jun 27, 2010 | 09:34 AM
cts1954's Avatar
cts1954
They are 8 inch wide rims, 2 inches to inner edge and 6 inches to outer edge.
The rims would not suit a stock truck but will look good on mine. Slightly lowered on the front and back with chrome grill and bumber, then under the hood I have a 255 flathead with dual strombergs and aluminum finned heads. Paint is going to be victory red cab and box with Mercidis moca black fenders.
Old Jun 27, 2010 | 10:05 AM
norvillebob
link:
https://www.rsracing.com/tech-wheel.html
I have 8.5" wheels from a mid 80's f150 they have 235/75/15 the back spacing is 3.75. I think I could run 3" in the rear but I would not go any lower then 3.5 in the fronts. reference for you..
Old Jun 27, 2010 | 12:06 PM
cts1954's Avatar
cts1954
Thanks, mine are 2 inch backspace, that is why I am concerned. I don't believe there will be any interference with the fender.
RojoStar
Aerostar
20
May 18, 2022 11:16 AM
melvinew2
Jun 16, 2016 02:01 PM
1998E250conversion
22
May 7, 2016 05:34 AM
BigBlue99
Jun 1, 2012 12:59 PM
