need help please
Old Jun 24, 2010 | 01:45 PM
subford's Avatar
subford
I said that a little wrong above an have changed it.
With no vacuum on the FPR (vacuum line off running or pin 2 to 6 jumped engine not running) you should get 45 PSI.
At idle with good vacuum and the vacuum line on the FPR you should get 32-34 PSI depending on the the vacuum going to the FPR.
At WOT you should get 40-42 PSI again depending on the the vacuum going to the FPR.
The fuel pump will put out about 95-100 PSI into a closed head. The FPR regulates this down depending on the vacuum level in the engine.
Originally Posted by LCAM-01XA
I'd imagine if the voltage fed to it is lower it would make a lower pressure
The voltage has nothing to do with the fuel pressure.
FPR: Fuel Pressure Regulator
Old Jun 24, 2010 | 07:29 PM
LCAM-01XA's Avatar
LCAM-01XA
I know that, hence why was just trying to figure out why an electric voodoo such as jumping 2-6 would make for different pressure readings. I do now understand what you meant tho.
bdent11
Modular V8 (4.6L, 5.4L)
Jun 19, 2016 09:18 PM
6ohguy
May 6, 2015 01:41 AM
Bodger
Jun 21, 2011 11:05 PM
40dog
Aug 3, 2010 11:30 PM
mooner
Jan 1, 2003 04:50 PM
