EBPV delete
Old Jun 23, 2010 | 04:50 PM
Warhippie's Avatar
Warhippie
EBPV delete
I was just reading a post on deleteing the EBPV and have a few guestions:
First what are the Pro's and Con's of this Mod.?
Second what is the function of the EBPV?
Third what else is needed in upgrades to do this Mod.?
Old Jun 23, 2010 | 06:18 PM
ChunderDownUnder's Avatar
ChunderDownUnder
EBPV is a butterfly valve at the exhaust outlet of the turbo that closes when you run a cold motor. It suppose to put a little extra strain on the motor to achieve a quicker warm up. Removing the valve takes away a restriction on the exhaust side giving a better flow. The main benefit is that you remove the actuator arm on the pedestal below the turbo which controls the valve. This arm is prone to leak oil. The only down side is it will take a little longer to warm up. But those who have done it dont report that being a issue. Basic tools are needed and a tap and plug. You can buy a replacement section to bolt on to the turbo when you remove the valve and a non EBVP pedestal
http://www.dieselsite.com/index.asp?...ROD&ProdID=237
http://www.dieselsite.com/index.asp?...ROD&ProdID=862
Or you can gut what you have
https://www.ford-trucks.com/forums/8...d-my-ebpv.html
Old Jun 23, 2010 | 06:25 PM
PaysonPSD's Avatar
PaysonPSD
Nice post Brian. Very concise and informatve, with links. Reps to you.
Mowing Man
Jul 30, 2013 06:29 PM
bubba_3711
Feb 8, 2013 07:18 AM
01EX
Jan 15, 2012 08:31 PM
eric777
Apr 19, 2007 02:20 PM
Miller
Mar 21, 2007 09:29 PM
