Help with distributor
Old Jun 23, 2010 | 11:08 AM
cjeffers9's Avatar
cjeffers9
i have a 1970 ford f-100 it has a 302 motor its a later model motor cause it has the smaller sparks plugs than a 1970 302 has but heres what im trying to do change the distributor from points to electronic found a 302 with what i need coil ,distributor.the wire to the box on the fender well that box has thee plugs on it can anybody tell me how to hook it up ??????????? cjeffers9@yahoo.com thanks
Old Jun 24, 2010 | 02:06 AM
bmuhlbach's Avatar
bmuhlbach
the box or module some have two plugs some have three.One plug goes to the dist.the other one should have a red wire and a white wire.One of them is power with key in the start position and the other is power with the key in the on position.I don't remeber which wire went where. It has been talked about before on here and some one had good info on splicing it in to your wireing could try a search.hope it helps you out.
jtgillam302
Jan 7, 2017 08:06 AM
RICHB99
Jan 4, 2017 12:57 PM
rlauer
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jan 18, 2014 09:21 AM
Boundsf150
Engine Swaps
Mar 12, 2010 09:28 PM
houdini
Dec 6, 2005 08:54 AM
